Hello all,
I was working with my BBB the other day and I was trying to get an OS other than Angstrom on it and I accidentally wrote the ubuntu img over the 73mb partition that shows up with BBB is plugged in. I have gathered that this is the boot partition and it seems right because when I try to boot it without an SD card the user lights never come on.
So I DDed the angstrom re flash image to an SD card to attempt to fix it but all four lights never come on to signify the re flash process is done and I’ve done this several times giving it a couple hours a try. Right now as I stare at it the left light does a double flash once per second and the third one flashes a bunch kinda sporadically. I read somewhere that you can’t plug ANYTHING into it or else it will just boot up which i hope isn’t true because all I have to power it is a USB cable and I tried a cell phone charger with it to no avail.
When I fdisk -l the 73MB partition does come up but has zero partitions. Does the reflash image not restore this? How do I restore this if not?
Lastly the very beginning of this was I was trying to install TTYLinux. Is there a tutorial for installing TTYLinux to BBB? I tried simply extracting the contents of the tar to my SD card but that didn’t seem to work. Not sure what other variables might have been mucking up that test at that point though.
