BBB Rev C power regulator failure with high-pitched whine - intermittent problem
My BBB Rev 3 was put into service 3 weeks ago. Noticed that board would periodically hang and need reboot. The board then ceased to start up at all. Board emits a high-pitched whine with no LEDs (including power LED) lit or flashing. No signs of life except the whine. Disconnected all but the wall-wart (5V 2A switching). Still LEDs flashing or lit, Pressing reset and power produced no result. Checked power voltage on connector and voltage was perfect. Un-jacked power (at BBB connector) and re-jacked. Still no LEDs lit or flashing. Still generating the high-pitched whine.
This morning, after submitting an email to RMA, I decided to try powering from USB to bypass the regulator. As a baseline, I connected the 5v wall-wart. This time, the BBB booted perfectly. No whine and LEDs now happily flashing. Connected over ssh/ethernet and logged in successfully.
Has anyone else seen this intermittent failure?
BeagleBone Black rev 000C S/N 3414BBBK0466 running BoneScript 0.2.4 at 192.168.1.156
Did a little reading. Problem must be in TPS65217C and USB power would not solve the problem.
This might be a duplicate of :
Possible TPS65217C/Beaglebone Black Issue
Whining is typically one of the inductors. Most likely the hosing has come loose.
You can request an RMA to get it replaced.
