Going back to a known-good image is always good. There have been many fixes and Robert has some images newer than on latest-images.
Can you post your .service file contents?
Hi Kurt,
Grab last night's build:
https://rcn-ee.net/rootfs/bb.org/testing/2016-12-27/iot/
There's still a few corner cases i'm debugging and tricky for users to
actually cause. (I also need to add a restart to the service file,
during first time bootup when the ssh key's take too long to
generate.)
Jason,
I’ve flashed back to the 12/18 image multiple times, and keep getting the same problem with connman. I’ll try the latest image from yesterday that Robert suggested.
Here on the contents of my .service file:
[Unit]
Description=Connection service
DefaultDependencies=false
Conflicts=shutdown.target
RequiresMountsFor=/var/lib/connman
After=dbus.service network-pre.target systemd-sysusers.service
Before=network.target multi-user.target shutdown.target
Wants=network.target[Service]
Type=dbus
BusName=net.connman
Restart=on-failure
ExecStart=/usr/sbin/connmand -n
StandardOutput=null
CapabilityBoundingSet=CAP_KILL CAP_NET_ADMIN CAP_NET_BIND_SERVICE CAP_NET_RAW C$
I believe in some circumstances I saw the above line preventing startup. I’m sure there is a good reason for it however.
