Welcome,
As for the beggining i would like to say tha im new to BeagleBoard enviroment , so please be patient.
I`m really curious if it is possible to use external USB hard drive (with own power supply) to use as main drive after boot sequence on BeagleBoard Black rev c.
I tried to follow up those instructions :
https://lumpynose.wordpress.com/2014/02/10/beaglebone-black-usb-hard-drive-boot-setup/
but they seem to be a little bit outdated sadly …
For now i have used following image flashed into eMMC :
https://rcn-ee.com/rootfs/2015-08-17/flasher/BBB-eMMC-flasher-debian-8.1-console-armhf-2015-08-17-2gb.img.xz
Any help with that matter would be much appreciated
Welcome,
BeagleBone Black USB hard drive boot setup | Lumpynose
but they seem to be a little bit outdated sadly ...
Do you have the kernel and rootfs on the usb hard-disk or only the rootfs?
In either case you need to modify the u-boot startup environment to
1) start usb
"usb start"
2) load kernel from usb drive to dram (if kernel is located on usb disk)
"ext4load scsi 0:2 ${loadaddr} /boot/zImage"
assuming the kernel image is in 2nd partition which is ext4 type and located at /boot/zImage.
3) load DT from usb drive to dram
"ext4load scsi 0:2 ${fdtaddr} /boot/am335x-boneblack.dtb
assuming the DT blob is in 2nd partition which is ext4 type and located at /boot/am335x-boneblack.dtb.
4) update linux boot arguments "bootargs" to point to the right rootfs dev. e.g. (root=/dev/sda2)
"setenv bootargs console=${console} ${optargs} root=/dev/sda2"
5) stop usb
"usb stop"
6) boot the kernel.
"bootz ${loadaddr} - ${fdtaddr}
Good luck!
cheers,
-roger
