I have a OURLINK wifi adapter
I can see the wifi, and it has a inet6 address, but not an ip address.
I can’t figure out why not?
I am using a wpa_supplicant.conf file which I know works (because it is the same file that works on my raspberry pi.
Can someone who knows what my problem is, tell me what I need to do?
lsusb output is:
us 001 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
ifconfig looks like this:
eth0 Link encap:Ethernet HWaddr 6c:ec:eb:ac:78:45
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:40
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:0
usb0 Link encap:Ethernet HWaddr e6:0b:5a:a8:76:94
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::e40b:5aff:fea8:7694/64 Scope:Link
RX packets:190 errors:0 dropped:0 overruns:0 frame:0
TX packets:39 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:54027 (52.7 KiB) TX bytes:10046 (9.8 KiB)
wlan0 Link encap:Ethernet HWaddr 00:e0:4c:0b:f3:ab
inet addr:10.0.1.19 Bcast:10.0.1.255 Mask:255.255.255.0
inet6 addr: fe80::2e0:4cff:fe0b:f3ab/64 Scope:Link
RX packets:282 errors:0 dropped:0 overruns:0 frame:0
TX packets:106 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:39482 (38.5 KiB) TX bytes:14832 (14.4 KiB)
My interfaces file looks like this:
auto lo
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
The primary network interface
#allow-hotplug eth0
#iface eth0 inet dhcp
Example to keep MAC address between reboots
#hwaddress ether DE:AD:BE:EF:CA:FE
The secondary network interface
#allow-hotplug eth1
#iface eth1 inet dhcp
WiFi Example
#iface wlan0 inet dhcp
wpa-ssid “essid”
wpa-psk “password”
Ethernet/RNDIS gadget (g_ether)
… or on host side, usbnet and random hwaddr
Note on some boards, usb0 is automaticly setup with an init script
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.0
network 192.168.7.0
gateway 192.168.7.1
