Howdy,
I’ve been using on board Angstrom on my tethered BBB; rsh and can compile, set date, etc. Attached ethernet and can rsh from my laptop. Most excellent.
Picked up a couple of 32B micro SDCards, but BBB won’t boot with them installed:
- Power off, insert FAT32 formated card in slot
- Apply power (not trying to boot, no buttons pressed)
- Get power LED, and all of the user LEDs lit. Nothiing else happens
I assumed a power issue from the microUSB (attached to a MAC). Picked up a AdaFruit 276 1A power supply. Same results:
- Only power supply and ethernet cable attached:
- Boot with no sd card inserted - no problem
- Boot with any sd card inserted - all LEDs lit, nothing happens.
Am I doing something wrong?
Suggestions?
Randy
Forgot to add that I can insert, mount and inspect the same card after the BBB is up and running. The issue is that I can’t power on boot with a card installed.
Randy
Howdy,
You need a serial cable attached as a console so that you can see where the boot it is failing. Since the LEDs light up tells us that u-boot is working but little else. We need the console log to see what is wrong.
John
Can I do so via the USB cable, or do I need a ‘real’ serial cable? Can you point me to instructions as I haven’t done that before?
Randy
I just ordered a AdaFruit debug cable. I’ll give it a try when it comes in and report what u-boot has to say.
Randy
I figured it out - my BBB is always trying to boot from the SB card, if one is installed, and I didn’t copy a correct bootable image on the card. I used dd to copy the latest image and it booted fine. Thanks!
