I ran the following from /opt/scripts/tools for no good reason other than curiosity:
update_bootloader.sh
update_kernel.sh
update_initrd.sh
Now my BBB goes to 4 solid blue lights if there is a microsd inserted during bootup. With no sd inserted, it boots up fine.
Serial log with sd inserted:
U-Boot SPL 2014.10-rc2-00017-g621bc23 (Sep 04 2014 - 19:58:48)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2014.10-rc2-00017-g621bc23 (Sep 04 2014 - 19:58:48), Build: jenkins-githu b_Bootloader-Builder-22
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
cpsw, usb_ether
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
SD/MMC found on device 1
reading uEnv.txt
1757 bytes read in 7 ms (245.1 KiB/s)
Checking if uenvcmd is set …
Running uenvcmd …
Bad Linux ARM zImage magic!
Checking if client_ip is set …
Error: “nandboot” not defined
U-Boot#
I can see it is obviously trying to boot off the sdcard and failing because there is no image on it. How can I fix this behavior an return it back no normal (so it won’t try to boot off the sdcard without S2 pressed) without reinstalling the system image?
