Hello all;
I can’t remember if there is a fix for this or not.
Basically when the USB-OTG port is connected to my PC, pulling the “power” signal low or
removing the +5V supply causes the BBB to power off briefly and then re-boot.
It seems to me that there must be a way to disable this, assuming that it is a “feature”.
Thanks ….
“No one could make a greater mistake than he who did nothing because he could do only a little.”
“All that is necessary for the triumph of evil is that good men do nothing” Edmond Burke (1729 - 1797)
http://www.packtpub.com/building-a-home-security-system-with-beaglebone/book
http://ca.linkedin.com/pub/bill-pretty/2b/b07/602
Hello all;
It seem that the watchdog timer is automatically enabled when the USB-OTG port is connected to a PC.
I am running the latest Debian release, and I am wondering if is possible to disable watchdog after boot.
Or after a user login ?
Do I use something like “close(watchdog)” in a login script ? Or is there another/better way ??
Thanks;
Bill
I just tried with latest debian and ti-kernel installed.
Powered up with 5V and usb otg connected to pc. Remove 5V:
michiel@arm:~$
Broadcast message from root@arm (Sun Mar 1 20:38:52 2015):
Power button pressed
The system is going down for system halt NOW!
clean shutdown and stays off.
This is the pmic input driver sending an ‘pwr_btn’ event which is catched by acpid which does a clean shut down (see /etc/acpid/…)
So this seems easy to configure. Only it doesn’t react the same as yours.
Now I’m going to look what you mean by watchdog (a black one? type beagle:)
regards,
Michiel
Ok, when I powered up with 5V and usb-otg connected to pc and I shortly press the power button I can replicate: clean shutdown and instant reboot
Don’t know where the reboot is coming from.
here’s pmic:
[ 2.897350] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
wrt. watchdog: I assume you mean /dev/watchdog I don’t think I have it active.
power button:
Linux arm 3.14.34-ti-r52 #1 SMP PREEMPT Fri Feb 27 16:52:54 UTC 2015 armv7l
Hi!
Last login: Sun Mar 1 21:17:01 2015 from quad
michiel@arm:~$ sudo cat /dev/input/event0 | xxd
0000000: 1274 f354 ae73 0d00 0100 7400 0100 0000 .t.T.s…t…
0000010: 1274 f354 ae73 0d00 0000 0000 0000 0000 .t.T.s…
0000020: 1374 f354 1d02 0200 0100 7400 0000 0000 .t.T…t…
0000030: 1374 f354 1d02 0200 0000 0000 0000 0000 .t.T…
Broadcast message from root@arm (Sun Mar 1 21:18:27 2015):
… and system reboots
Hi Toni;
I think I have it figured out.
I have an image that works and one that doesn’t.
Watchdog Not enabled:
Linux beaglebone 3.8.13-bone47 #1 SMP Fri Apr 11 01:36:09 UTC 2014 armv7l GNU/Linux
Watchdog enabled:
Linux beaglebone 3.8.13-bone50 #1 SMP Tue May 13 13:24:52 UTC 2014 armv7l GNU/Linux
Image “bone47” works like yours does. Clean shutdown with no reboot and no “watchdog enabled” boot message.
It would appear that this was changed by version “bone50”
Thanks to Google, I found a code snippit, that should work.
