I have problem making the gpios on BBB work. I prepare patch for the dts and apply it .
I think I have apply it successfully because when I check the “pins” file I get this.
$ cat /sys/kernel/debug/pinctrl/44e10800.pinmux-pinctrl-single/pins
pin 36 (PIN36) 2:gpio-32-63 44e10890 0000000f pinctrl-single
pin 37 (PIN37) 3:gpio-32-63 44e10894 0000000f pinctrl-single
(it used to be 00000037 now its 0000000f)
I also added “gpioinfo” to my image by adding CORE_IMAGE_EXTRA_INSTALL += “libgpiod libgpiod-dev libgpiod-tools” to the recipe and now gpioinfo shows:
$ gpioinfo
gpiochip1 - 32 lines:
line 2: "P8_7" unused output active-high
line 3: "P8_8" unused output active-high
I tried to control the pins in two ways
- using gpioset
$ gpioset gpiochip1 2=1
- with /sys/clas/gpio
$ echo 66 > /sys/class/gpio/export
$ echo out > /sys/class/gpio/gpio66/direction
$ echo 0 > /sys/class/gpio/gpio66/value
However, neither one works.
These are details about my dts patch:
- linux-yocto/arch/arm/boot/dts/am335x-boneblack.dts - inside the file added
&am33xx_pinmux {
pinctrl-names = "default";
pinctrl-0 = <&gpio_pins>;
status = "okay";
- linux-yocto/arch/arm/boot/dts/am335x-bone-common.dtsi - inside the &am33xx_pinmux added
&am33xx_pinmux {
pinctrl-0 = <&clkout2_pin>;
gpio_pins: pinmux_gpio_pins {
pinctrl-single,pins = <
AM33XX_PADCONF(AM335X_PIN_GPMC_ADVN_ALE, PIN_OUTPUT, MUX_MODE7) /* gpio2_2 */
AM33XX_PADCONF(AM335X_PIN_GPMC_OEN_REN, PIN_OUTPUT, MUX_MODE7) /* gpio2_3 */
It seems that at some way the dts change that I patch is working. But this gpioinfo status “unused” bothers me.
I think that I’m missing something. Something else to enable the pgio pins.
Please help me.
