I use Ubuntu 18 KDE Plasma.
But $lsusb doesn’t return new devices
$ ifconfig -a doesnt show new network interfaces
However I use FTDI serial to USB convertor and the hardware serial is working.
So the image that I have build is working but I don’t have usb connection.
Is the image that I use correct,I don’t see nothing in $ lsusb?
How can I make it work?
I followed this guide too Building BeagleBone Systems with Yocto, it is using poky-dunfell distribution.
But it is the same thing, when I’m building the yocto myself I don’t have the internet connection through USB.
Any ideas, do I need to set some parameter in local.conf or something?
The USB gadget hasn’t been enabled. I had to enable it.
To do this I created append recipe for the kernel - linux-yocto_5.15.bbappend which calls cfg file.
MY_CONFIG_FILE = “${TOPDIR}/…/poky/meta-mms-bsp/recipes-kernel/linux”
SRC_URI += “file://${MY_CONFIG_FILE}/my_custom.cfg”
This is layer created by me. The important thing is to make in your own layer a kernel append recipe. In this case linux-yocto_5.15.bbappend.
Put the rows from my previous post inside and make own custom.cfg file that contains these USB settings.
(Actually you can make the append file with universal name, not depending of the selected kernel version but I forgot how exactly was the naming in this case)
