I have a python script running on a raring BBBLack ubuntu image that has wiFi working flawlessly, but while using the python script as follows I’m see that the script runs but the Request Log on the xively dashboard isn’t receiving anything?!
Is there a frequency limit for which I can update the feeds?
Or is it my App? Which I think is running and not going down.
here’s the code:
#!/usr/bin/env python
import os
import xively
import subprocess
import time
import datetime
import requests
import serial
import re
import string
from select import select
#OS variables and other settings for UART transfer
os.system("sudo chmod 777 -R /sys/devices/bone_capemgr.8/slots")
os.system("sudo echo ttyO1_armhf.com > /sys/devices/bone_capemgr.8/slots")
serial = serial.Serial("/dev/ttyO1", baudrate=9600)
resp = ""
inData = ['']*14
started = False
ended = False
check_point = 0
check_point_listener = 0
# extract feed_id and api_key from environment variables
FEED_ID = "34534"
API_KEY = "blahhblahh"
DEBUG = "DEBUG" or false
DEBUG_listener = "DEBUG" or false
# initialize api client
api = xively.XivelyAPIClient(API_KEY)
# function to return a datastream object. This either creates a new datastream,
# or returns an existing one
def get_datastream(feed):
try:
datastream = feed.datastreams.get("Lock_Controller")
if DEBUG:
print "Found existing datastream"
return datastream
except:
if DEBUG:
print "Creating new datastream"
datastream = feed.datastreams.create("Lock_Controller", tags="ON/OFF")
return datastream
def get_datastream_listener(feed):
try:
datastream_listener = feed.datastreams.get("load_avg")
if DEBUG:
return datastream_listener
except:
if DEBUG:
datastream_listener = feed.datastreams.create("load_avg", tags="load_01")
# main program entry point - runs continuously updating our datastream with the
def run():
print "Script initiation"
#Initializing one channel
feed = api.feeds.get(FEED_ID)
datastream = get_datastream(feed)
datastream.max_value = None
datastream.min_value = None
feed_listener = api.feeds.get(FEED_ID)
datastream_listener = get_datastream_listener(feed_listener)
datastream_listener.max_value = None
datastream_listener.min_value = None
while True:
while serial.inWaiting() > 0:
inChar = serial.read() # Read a character
if inChar =='<': # not sure what to put in if statement to run until end
global started
started = True
global ended
ended = False
index = 0
elif inChar =='>':
global ended
ended = True
if started == True:
inData[index] = inChar # Store it
index = index + 1 # Increment where to write next
#inData[index] = '\0' # Null terminate the string
if ended == True:
global ended
ended = False
index = 0
Data = inData #values of acclerometer like "545X" etc enter and stored in Data
print (Data)
values = "".join(str(v) for v in Data)
print (values)
strData = string.replace(values, "<", "")
strData = string.replace(strData, ">", "")
strData = string.replace(strData, " ", "")
strData = string.replace(strData, "\0", "")
print (strData)
if strData[0] == 's' and strData[1] == 't':
print "Nishant Here"
strData = string.replace(strData, "st", "")
print strData
if strData == '1':
print "This is arrived at 1"
global check_point_listener
datastream_listener.current_value = str(check_point_listener) + "h"
datastream_listener.update()
#serial.write("<v0" + str(check_point) + ">") #serial write value
time.sleep(1)
datastream_listener.current_value = 0
elif strData == '0':
print "This is arrived at 0"
datastream_listener.current_value = str(check_point_listener) + "L"
time.sleep(1)
if DEBUG:
print "Updating Xively feed with value: %s"
global check_point
check_point = 0
global check_point
check_point = datastream.current_value
print "AAGYa: %s" % check_point
for x in range(1,61):
#print x
checking = int(check_point)
if x == checking:
print "Got it"
serial.write("<ch" + str(x) + ">")
datastream.current_value = 0
datastream.update()
if DEBUG_listener:
print "Query stuff: %s"
check_point_listener = datastream_listener.current_value
print "AAGYa: %s" % check_point_listener
check_point_listener = string.replace(check_point_listener, "L", "")
check_point_listener = string.replace(check_point_listener, "h", "")
#print x
checking = int(check_point_listener)
if x == checking:
print "Got it Query"
serial.write("<Q" + str(x) + ">")
run()
