Hello
I’ve got three BeagleBoneBlacks purchased from Digikey last week. On reprogramming them to - Debian 9.4 2018-06-17 4GB SD LXQT or 4.14.49-ti-r54 #1 SMP PREEMPT Fri Jun 15 22:14:13 UTC 2018 -
they appear to come up as BBG. They aren’t activating the HDMI…
An earlier board with the same microSD disk boots OK.
They start by booting as Black, but then dmesg shows they become a green.
I’m wondering if anybody has any ideas.
----------------------Boot, df, version.sh, dmesg-----------
U-Boot 2018.03-00002-gac9cce7c6a (Apr 05 2018 - 13:07:46 -0500), Build: jenkins-github_Bootloader-Builder-47
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
RTC 32KCLK Source: External.
Loading Environment from EXT4… Card did not respond to voltage select!
** Bad device mmc 0 **
Failed (-5)
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[BBG1] …
switch to partitions #0, OK
Scanning mmc 1:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
2086 bytes read in 14 ms (145.5 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.14.49-ti-r54 …
10453504 bytes read in 676 ms (14.7 MiB/s)
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] …
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] …
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb …
loading /boot/dtbs/4.14.49-ti-r54/am335x-boneblack-uboot.dtb …
57952 bytes read in 35 ms (1.6 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /lib/firmware/M-BB-BBG-00A0.dtbo …
277 bytes read in 142 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo …
1440 bytes read in 46 ms (30.3 KiB/s)
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo …
711 bytes read in 204 ms (2.9 KiB/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo …
3513 bytes read in 110 ms (30.3 KiB/s)
uboot_overlays: loading /lib/firmware/univ-bbb-Exx-00A0.dtbo …
105020 bytes read in 185 ms (553.7 KiB/s)
loading /boot/initrd.img-4.14.49-ti-r54 …
4247817 bytes read in 284 ms (14.3 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet] …
debug: [bootz 0x82000000 0x88080000:40d109 88000000] …
Loading Ramdisk to 8fbf2000, end 8ffff109 … OK
reserving fdt memory region: addr=88000000 size=87000
Loading Device Tree to 8fb68000, end 8fbf1fff … OK
Starting kernel …
[ 0.002215] timer_probe: no matching timers found
[ 0.625749] dmi: Firmware registration failed.
[ 1.145843] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.492814] omap_voltage_late_init: Voltage driver support not added
Debian GNU/Linux 9 beaglebone ttyS0
BeagleBoard.org Debian Image 2018-06-17
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
beaglebone login: debian
Password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
df -h
debian@beaglebone:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 215M 0 215M 0% /dev
tmpfs 49M 5.1M 44M 11% /run
/dev/mmcblk1p1 3.5G 2.7G 568M 83% /
tmpfs 242M 0 242M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 242M 0 242M 0% /sys/fs/cgroup
tmpfs 49M 0 49M 0% /run/user/1000
debian@beaglebone:~$ ^V
-bash: $’\026’: command not found
debian@beaglebone:~$ ^M
-bash: $’\r’: command not found
debian@beaglebone:~$ sudo /opt/scripts/tools/version.sh
[sudo] password for debian:
git:/opt/scripts/:[31292bce1d4b35b497cc7a013d6d57e7e1f4f5c4]
]eprom:[A335BNLTBBG020Q
model:[TI_AM335x_BeagleBone_Green]
dogtag:[BeagleBoard.org Debian Image 2018-06-17]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.03-00002-gac9cce7c6a]:[location: dd MBR]
kernel:[4.14.49-ti-r54]
nodejs:[v6.14.3]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.4.20180611.0-0rcnee0~stretch+20180611]
pkg:[bb-wl18xx-firmware]:[1.20180517-0rcnee0~stretch+20180517]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
pkg:[roboticscape]:[0.4.4-git20180608.0-0rcnee0~stretch+20180609]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee1~stretch+20180328]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c bluetooth netdev cloud9ide gpio pwm eqep admin spi tisdk weston-launch xenomai]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet]
dmesg | grep pinctrl-single
[ 1.123951] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
dmesg | grep gpio-of-helper
[ 1.134585] gpio-of-helper ocp:cape-universal: ready
END
debian@beaglebone:~$ dmesg
[ 0.000000] Linux version 4.14.49-ti-r54 (root@b2-am57xx-beagle-x15-2gb) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)) #1 SMP PREEMPT Fri Jun 15 22:14:13 UTC 2018
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Green
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
