Apologies if this is a silly question. I am new to both the beagle bone and debian.
I have successfully booted my BBBW using a few different images from https://rcn-ee.com/rootfs/bb.org/testing. Everything goes well including the initial wifi setup using connman. However, after I configure my wifi using a method similar to that mentioned here: https://www.ccoderun.ca/programming/2016-12-18_BBBW/index.html#wifi, and I reboot, my connman doesn’t seem to function the same.
Following a successful boot from a fresh image, and a successful initial wifi setup, and then a reboot, I get the following when running sudo connmanctl:
Error getting VPN connections: The name net.connman.vpn was not provided by any .service filesconnman
Error getting technologies: The name net.connman was not provided by any .service filesconnmanctl
I see the following if I then run sudo ifconfig -a
SoftAp0 Link encap:Ethernet HWaddr 50:65:83:e0:ac:06
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
inet6 addr: fe80::5265:83ff:fee0:ac06/64 Scope:Link
TX packets:28 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:6475 (6.3 KiB)
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:16 Metric:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:196
can1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
Interrupt:197
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:404 errors:0 dropped:0 overruns:0 frame:0
TX packets:404 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:31907 (31.1 KiB) TX bytes:31907 (31.1 KiB)
usb0 Link encap:Ethernet HWaddr 50:65:83:e0:ac:05
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
inet6 addr: fe80::5265:83ff:fee0:ac05/64 Scope:Link
RX packets:1239 errors:0 dropped:0 overruns:0 frame:0
TX packets:227 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:190327 (185.8 KiB) TX bytes:43688 (42.6 KiB)
wlan0 Link encap:Ethernet HWaddr 50:65:83:e0:ac:03
BROADCAST MULTICAST MTU:1500 Metric:1
Is this normal behavior, and am I just misunderstanding things?
I have tried flashing my BBBW (fresh from Digi Key) with a few different images from https://rcn-ee.com/rootfs/bb.org/testing. I have tried 2017-02-05, and 2017-02-12, both bone-debian-8.6-lxqt-4gb-armhf versions. Both respond the same way in terms of connman behavior following initial setup and reboot.
Any advice would be greatly appreciated.
Thanks!
Tom
