BBBW Ubuntu Wi-Fi: wlcore: ERROR Your WiFi FW version (8.9.0.0.39) is invalid.
I’m having some issues setting up the Wi-Fi on BBBW with BBB-eMMC-flasher-ubuntu-16.04.2-console-armhf-2017-04-07-2gb.img.xz image from http://elinux.org/BeagleBoardUbuntu#All_BeagleBone_Varients
After the image was installed onto the eMMC, I upgraded the kernel:
$ cd /opt/scripts/tools/ $ git pull $ sudo ./update_kernel.sh --ti-kernel --lts-4_9
After upgrading the kernel to v4.9, I couldn’t get the Wi-Fi to connect, and the following error messages were printed out on the console at the end of the boot process:
[ 24.915588] wlcore: ERROR error getting static data [ 25.380198] wlcore: ERROR Your WiFi FW version (8.9.0.0.39) is invalid. [ 25.380198] Please use at least FW 8.9.*.*.58. [ 25.380198] You can get the latest firmwares at: [ 25.380198] git://git.ti.com/wilink8-wlan/wl18xx_fw.git [ 25.401435] wlcore: ERROR error getting static data [ 25.409231] wlcore: ERROR firmware boot failed despite 3 retries [ 26.028516] wlcore: ERROR Your WiFi FW version (8.9.0.0.39) is invalid. [ 26.028516] Please use at least FW 8.9.*.*.58. [ 26.028516] You can get the latest firmwares at: [ 26.028516] git://git.ti.com/wilink8-wlan/wl18xx_fw.git [ 26.049583] wlcore: ERROR error getting static data [ 26.512322] wlcore: ERROR Your WiFi FW version (8.9.0.0.39) is invalid. [ 26.512322] Please use at least FW 8.9.*.*.58. [ 26.512322] You can get the latest firmwares at: [ 26.512322] git://git.ti.com/wilink8-wlan/wl18xx_fw.git [ 26.533368] wlcore: ERROR error getting static data [ 26.999724] wlcore: ERROR Your WiFi FW version (8.9.0.0.39) is invalid. [ 26.999724] Please use at least FW 8.9.*.*.58. [ 26.999724] You can get the latest firmwares at: [ 26.999724] git://git.ti.com/wilink8-wlan/wl18xx_fw.git [ 27.021019] wlcore: ERROR error getting static data [ 27.028754] wlcore: ERROR firmware boot failed despite 3 retries
However, it looks like I’ve got the latest firmware package installed:
ubuntu@arm:~$ sudo apt-get install bb-wl18xx-firmware Reading package lists... Done Building dependency tree Reading state information... Done bb-wl18xx-firmware is already the newest version (1.20170406-0rcnee0~bpo1604+20170406). 0 upgraded, 0 newly installed, 0 to remove and 14 not upgraded.
More version info:
ubuntu@arm:/opt/scripts/tools$ sudo ./version.sh git:/opt/scripts/:[65bfaaf97e1bb09517752b717ce29882dc99efda] eeprom:[A335BNLTBWA51652BBWG0552] dogtag:[rcn-ee.net console Ubuntu Image 2017-04-07] bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2017.05-rc1-00002-g35aecb] kernel:[4.9.21-ti-r30]
Following the instructions in the error messages, I cloned git://git.ti.com/wilink8-wlan/wl18xx_fw.git and copied wl18xx-fw-4.bin into /lib/firmware/ti-connectivity/
Rebooted the system and the firmware version error messages disappeared.
However, getting the Wi-Fi to connect on reboot still seems to be a bit flaky. After each reboot, Wi-Fi doesn’t work until I run “agent on”, “disable wifi”, “enable wifi”, and then “scan wifi”. This magic incantation seems to work each time…
See the sequence below for the steps I tried to get the (previously configured/working) Wi-Fi to re-connect after reboot:
ubuntu@arm:/opt/scripts/tools$ ping google.com
connect: Network is unreachable
ubuntu@arm:/opt/scripts/tools$ sudo connmanctl
disable wifi
Disabled wifi
enable wifi
Enabled wifi
scan wifi
Error /net/connman/technology/wifi: No carrier
agent on
Agent registered
scan wifi
disable wifi
Disabled wifi
enable wifi
Enabled wifi
scan wifi
Scan completed for wifi
services
*** I removed the list of services ***
technologies
Name = WiFi
Type = wifi
Powered = True
Connected = True
Tethering = False
/net/connman/technology/bluetooth
Name = Bluetooth
Type = bluetooth
Powered = True
Connected = False
Tethering = False
quit
Is there a better way to get the Wi-Fi working reliably on the Ubuntu 16.04 image? I’m totally new to BeagleBone (just bought one yesterday), so I’m not sure if I goofed some part of the setup… any advice on the Wi-Fi configuration in Ubuntu would be welcome!
I'm having some issues setting up the Wi-Fi on BBBW with
$ git pull
After upgrading the kernel to v4.9, I couldn't get the Wi-Fi to connect, and
the boot process:
this must be a recent change, haven't ran into that yet..
However, it looks like I've got the latest firmware package installed:
More version info:
flaky. After each reboot, Wi-Fi doesn't work until I run "agent on",
"disable wifi", "enable wifi", and then "scan wifi". This magic incantation
seems to work each time...
> disable wifi
Disabled wifi
> enable wifi
Enabled wifi
> scan wifi
> agent on
Agent registered
> scan wifi
> disable wifi
Disabled wifi
> enable wifi
Enabled wifi
> scan wifi
> services
> technologies
  Name = WiFi
  Type = wifi
  Powered = True
  Connected = True
  Tethering = False
  Name = Bluetooth
  Type = bluetooth
  Powered = True
  Connected = False
  Tethering = False
> quit
image? I'm totally new to BeagleBone (just bought one yesterday), so I'm
not sure if I goofed some part of the setup... any advice on the Wi-Fi
So we are still shipping v4.4.x-ti by default, v4.9.x only lightly
tested, looks like ti changed something with the firmware again..
So the firmware was generated by the command shown here:
https://github.com/beagleboard/beaglebone-black-wireless/tree/master/firmware
Grab that WL1835MOD_INI_C2PC.ini and give it shot again.
Hi Robert,
Sorry, I failed to mention earlier that the only reason why I tried upgrading from v4.4 → v4.9 was because I was seeing the same flaky behavior (no network connection on reboot) with a brand new install of BBB-eMMC-flasher-ubuntu-16.04.2-console-armhf-2017-04-07-2gb.img.xz. I thought maybe the newer kernel might fix things, but instead it introduced the new firmware error messages I posted above.
I’m not sure I understand what you’re asking me to try in the above post. If I’m reading it correctly, the github link you sent shows how to generate wl18xx-conf.bin (I’m assuming this is some kind of config binary???), but the only file I replaced in my v4.9 experiment was the wl18xx-fw-4.bin (which I’m assuming is the firmware binary???). Wouldn’t the wl18xx-conf.bin I re-generate from WL1835MOD_INI_C2PC.ini be exactly the same as the one already included in BBB-eMMC-flasher-ubuntu-16.04.2-console-armhf-2017-04-07-2gb.img.xz? It seems like the error messages were complaining about the firmware version, rather than an issue with the config binary.
Chris
