BBG Fast Bootup
Dear All,
I am using beaglebone green with 7 inc $d LCD cape. I am running QT application at startup.
But it takes about 25 seconds start the QT application. I tried many ways.
Here is the dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13-bone70 (demos@demos) (gcc version 4.7.3 20130328 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.04-20130415 - Linaro GCC 2013.04) ) #3 SMP Thu Jul 7 10:27:12 IST 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 130816
[ 0.000000] free_area_init_node: node 0, pgdat c08b09c0, node_mem_map c092e000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 129792 pages, LIFO batch:31
[ 0.000000] AM335X ES2.1 (l2cache sgx neon )
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c0d3e000 s14080 r8192 d14592 u36864
[ 0.000000] pcpu-alloc: s14080 r8192 d14592 u36864 alloc=9*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 text vt.global_cursor_default=0 capemgr.disable_partno=BB-BONELT-HDMI root=UUID=d3391e8f-ad03-466b-8d9e-4cf7d119d7a6 ro rootfstype=ext4 rootwait fixrtc quiet
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 505432k/505432k available, 18856k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07cef38 (7964 kB)
[ 0.000000] .init : 0xc07cf000 - 0xc082a700 ( 366 kB)
[ 0.000000] .data : 0xc082c000 - 0xc08b3980 ( 543 kB)
[ 0.000000] .bss : 0xc08b3980 - 0xc092d100 ( 486 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:0 nr_irqs:0 0
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000228] Calibrating delay loop… 993.47 BogoMIPS (lpj=969728)
[ 0.029188] pid_max: default: 32768 minimum: 301
[ 0.029324] Security Framework initialized
[ 0.029379] Mount-cache hash table entries: 512
[ 0.035020] Initializing cgroup subsys cpuacct
[ 0.035071] Initializing cgroup subsys memory
[ 0.035114] Initializing cgroup subsys blkio
[ 0.035200] CPU: Testing write buffer coherency: ok
[ 0.035576] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.035629] Setting up static identity map for 0x804a5338 - 0x804a5384
[ 0.036547] Brought up 1 CPUs
[ 0.036560] SMP: Total of 1 processors activated (993.47 BogoMIPS).
[ 0.037343] devtmpfs: initialized
[ 0.045838] omap_hwmod: wd_timer2: _wait_target_disable failed
[ 0.097950] pinctrl core: initialized pinctrl subsystem
[ 0.098083] rstctl core: initialized rstctl subsystem
[ 0.098363] regulator-dummy: no parameters
[ 0.098678] NET: Registered protocol family 16
[ 0.099254] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.104878] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.105464] platform 49000000.edma: alias fck already exists
[ 0.105480] platform 49000000.edma: alias fck already exists
[ 0.105493] platform 49000000.edma: alias fck already exists
[ 0.106107] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.106199] OMAP GPIO hardware version 0.1
[ 0.106995] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.107700] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.108381] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.108639] of_get_named_gpio_flags exited with status 52
[ 0.108655] gpio-rctrl rstctl.4: loaded OK
[ 0.111936] No ATAGs?
[ 0.111952] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.113259] cpsw.0: No hwaddr in dt. Using 84:eb:18:e1:ea:b3 from efuse
[ 0.113277] cpsw.1: No hwaddr in dt. Using 84:eb:18:e1:ea:b5 from efuse
[ 0.121428] bio: create slab at 0
[ 0.127732] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.127889] of_get_named_gpio_flags: can’t parse gpios property
[ 0.128010] vmmcsd_fixed: 3300 mV
[ 0.129590] SCSI subsystem initialized
[ 0.129828] usbcore: registered new interface driver usbfs
[ 0.129887] usbcore: registered new interface driver hub
[ 0.130087] usbcore: registered new device driver usb
[ 0.131350] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.132235] input: tps65217_pwr_but as /devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.133837] DCDC1: at 1500 mV
[ 0.134696] vdd_mpu: 925 <–> 1325 mV at 1325 mV
[ 0.135501] vdd_core: 925 <–> 1150 mV at 1125 mV
[ 0.136297] LDO1: at 1800 mV
[ 0.137126] LDO2: at 3300 mV
[ 0.138595] LDO3: 1800 mV
[ 0.139395] LDO4: at 3300 mV
[ 0.140103] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.140593] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.141065] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.142398] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.142602] media: Linux media interface: v0.10
[ 0.142667] Linux video capture interface: v2.00
[ 0.142735] pps_core: LinuxPPS API ver. 1 registered
