BBGW Kernel Panic
I’m encountering a kernel panic when I try to unload the “univ-bbgw” cape from my $SLOTS file.
My setup is:
Seeed BeagleBone Green Wireless
Seeed Grove Base Cape for Beaglebone v2.0
bone-debian-8.7-seeed-iot-armhf-2017-03-26-4gb
Here’s my terminal output and dmesg of the error: https://gist.github.com/alexmullins/a4f9673b2cb280679b8df11be1f4140f.
I think this is the relevant part of dmseg:
[ 380.483327] Unable to handle kernel NULL pointer dereference at virtual address 0000000d
[ 380.491655] pgd = db5d4000
[ 380.494384] [0000000d] *pgd=9b533831, *pte=00000000, *ppte=00000000
[ 380.500908] Internal error: Oops: 17 [#1] SMP ARM
I’ve looked at the univ-bbgw.dts and I don’t see anything out of the ordinary there (I’m not great with device trees though).
Also, I’m noticing that the Seeed Grove Base Cape for Beaglebone v2.0 doesn’t have a valid EEPROM signature:
[ 2.554339] bone_capemgr bone_capemgr: Invalid signature ‘ffffffff’ at slot 3
Not sure if that could have something to do with this.
Does anyone have any tips on where to go from here?
-Alex
I'm encountering a kernel panic when I try to unload the "univ-bbgw" cape
My setup is:
Here's my terminal output and dmesg of the error:
kernel panic trying to unload univ-bbgw with "echo -5 > $SLOTS" · GitHub.
address 0000000d
I've looked at the univ-bbgw.dts and I don't see anything out of the
ordinary there (I'm not great with device trees though).
That's normal, removing a cape via slots almost never works..
Instead in /boot/uEnv.txt find the "cape_universal=enable", remove
that and reboot.
Also, I'm noticing that the Seeed Grove Base Cape for Beaglebone v2.0
doesn't have a valid EEPROM signature:
[ 2.554339] bone_capemgr bone_capemgr: Invalid signature 'ffffffff' at
slot 3
a custom overlay needs to be written for this cape.
My setup is:
address 0000000d
That’s normal, removing a cape via slots almost never works…
Instead in /boot/uEnv.txt find the “cape_universal=enable”, remove
that and reboot.
Is the ‘univ-bbgw’ loaded on boot when cape_universal=enable? I ask because I
only see it in my $SLOTS file after I mess around with a few pins.
slot 3
Everything seems to work fine with the ‘univ-bbgw’ overlay so I’ll let it be for now.
Thanks RCN!
