BBGW ubuntu connman
Hello
I am using ubuntu-16.04.2-console-armhf-2017-03-09.tar.xz
I want to connect wifi using connman.
but …
ubuntu@arm:/sbin$ sudo connmanctl scan wifi
Error /net/connman/technology/wifi: No carrier
ubuntu-16.04.1-console-armhf-2017-01-23.tar.xz are the same.
debian images works normally(debian-8.7-console-armhf-2017-03-09.tar.xz, debian-8.7-iot-armhf-2017-01-15.tar.xz)
What should I see?
Below are the wpa_supplicant status results for ubuntu and debian.
ubuntu@arm:/sbin$ sudo systemctl status wpa_supplicant.service
[sudo] password for ubuntu:
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/lib/systemd/system/wpa_supplicant.service; disabled; vendor
Active: active (running) since Fri 2017-03-10 05:14:32 UTC; 2min 43s ago
Main PID: 648 (wpa_supplicant)
CGroup: /system.slice/wpa_supplicant.service
└─648 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
Mar 10 05:14:31 arm systemd[1]: Starting WPA supplicant…
Mar 10 05:14:32 arm wpa_supplicant[648]: Successfully initialized wpa_supplicant
Mar 10 05:14:32 arm systemd[1]: Started WPA supplicant.
Mar 10 05:14:40 arm wpa_supplicant[648]: dbus: wpa_dbus_get_object_properties: f
Mar 10 05:14:40 arm wpa_supplicant[648]: dbus: Failed to construct signal
Mar 10 05:14:40 arm wpa_supplicant[648]: Could not read interface p2p-dev-wlan0
debian@arm:/sbin$ sudo systemctl status wpa_supplicant.service
Active: active (running) since Fri 2017-03-10 04:55:05 UTC; 1min 53s ago
Main PID: 1164 (wpa_supplicant)
└─1164 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
Mar 10 04:55:04 arm systemd[1]: Starting WPA supplicant…
Mar 10 04:55:04 arm wpa_supplicant[1164]: Successfully initialized wpa_supplican
Mar 10 04:55:05 arm systemd[1]: Started WPA supplicant.
Mar 10 04:55:24 arm wpa_supplicant[1164]: Could not read interface p2p-dev-wlan0
Mar 10 04:55:24 arm wpa_supplicant[1164]: WPS: Converting push_button to virtual
Mar 10 04:55:24 arm wpa_supplicant[1164]: p2p-dev-wlan0: CTRL-EVENT-REGDOM-CHANG
I found problem.
ubuntu@arm:~$ sudo connmanctl scan wifi
ubuntu@arm:~$ sudo connmanctl services
ubuntu@arm:~$
I try wifi disable/re-enable.
ubuntu@arm:~$ sudo connmanctl disable wifi
Disabled wifi
ubuntu@arm:~$ sudo connmanctl enable wifi
Enabled wifi
NPcom wifi_785c7878785c_4e50636f6d_managed_psk
It need to enable/disable wifi muliple times.
Which part should I look at?
2017년 3월 30일 목요일 오전 11시 29분 17초 UTC+9, Kyung-Dong Hong 님의 말:
I have the same problem too. I’ve got that wifi works enable/disable but i need to do it every time i turn on the BBG.
