Update 1: I’ve also tried evtest .
evtest does show that it’s loaded as an input driver though.
Sample dump :
root@omap:/dev/input# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: gpio-keys
/dev/input/event1: Logitech USB Optical Mouse
/dev/input/event2: Cherry GmbH SmartBoard XX44
/dev/input/event3: ti-tsc-adcc
Select the device event number [0-3]: 3
Input driver version is 1.0.1
Input device ID: bus 0x0 vendor 0x0 product 0x0 version 0x0
Input device name: "ti-tsc-adcc"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 2951
Min 0
Max 4095
Event code 1 (ABS_Y)
Value 2425
Min 0
Max 4095
Testing … (interrupt to exit)
(continued…)
Event: time 1345235575.186246, -------------- SYN_REPORT ------------
Event: time 1345235575.187436, type 3 (EV_ABS), code 0 (ABS_X), value 3557
Event: time 1345235575.187436, type 3 (EV_ABS), code 1 (ABS_Y), value 2107
Event: time 1345235575.187467, -------------- SYN_REPORT ------------
Event: time 1345235575.189817, type 3 (EV_ABS), code 0 (ABS_X), value 3554
Event: time 1345235575.189817, type 3 (EV_ABS), code 1 (ABS_Y), value 2116
Event: time 1345235575.189847, -------------- SYN_REPORT ------------
Event: time 1345235575.191007, type 3 (EV_ABS), code 0 (ABS_X), value 3551
Event: time 1345235575.191038, type 3 (EV_ABS), code 1 (ABS_Y), value 2107
Event: time 1345235575.191038, -------------- SYN_REPORT ------------
Event: time 1345235575.193387, type 3 (EV_ABS), code 0 (ABS_X), value 3547
Event: time 1345235575.193387, type 3 (EV_ABS), code 1 (ABS_Y), value 2109
Event: time 1345235575.193387, -------------- SYN_REPORT ------------
Event: time 1345235575.194578, type 3 (EV_ABS), code 0 (ABS_X), value 3548
Event: time 1345235575.194578, type 3 (EV_ABS), code 1 (ABS_Y), value 2112
Event: time 1345235575.194608, -------------- SYN_REPORT ------------
Event: time 1345235575.205167, type 3 (EV_ABS), code 0 (ABS_X), value 3554
Event: time 1345235575.205167, type 3 (EV_ABS), code 1 (ABS_Y), value 2111
Event: time 1345235575.205198, -------------- SYN_REPORT ------------
Event: time 1345235575.212247, type 3 (EV_ABS), code 0 (ABS_X), value 3556
Event: time 1345235575.212247, type 3 (EV_ABS), code 1 (ABS_Y), value 2115
Event: time 1345235575.212247, -------------- SYN_REPORT ------------
Event: time 1345235575.213437, type 3 (EV_ABS), code 0 (ABS_X), value 3557
Event: time 1345235575.213437, type 3 (EV_ABS), code 1 (ABS_Y), value 2116
Event: time 1345235575.213437, -------------- SYN_REPORT ------------
Event: time 1345235575.217283, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1345235575.217313, -------------- SYN_REPORT ------------
Could there be a problem with my export? Or settings for the tslib library?
Again, any input would be greatly appreciated . Cheers!
Sideline: I don’t want to be tied up using Angstrom distribution as my base system for my project, as I’m at a point where I need something that’s better “supported”.
Not that I have anything against Angstrom which I find it’s adequate, but I’m much more familiar with Ubuntu and Debian. Cheers!
