BBW custom 3.5 LCD
Hi everyone, I’m trying to connect a 3.5" LCD to a BBW, I’m basing my connections from the LCD3 cape, however the LCD parameters are different (HFP, etc) which I know the right values.
I would like to know which files do I have to modify (or add) with the LCD information and how do I configure that the BBW boots using the LCD.
I have a little experience with linux and BB in general.
Thank you for your help.
I would start by looking at the dts file, for an existing LCD cape, in /lib/firmware
You can modify it, compile it to a dtbo file, and then load it as a test cape for testing. This is assuming you are using the 3.8 Kernel.
You should check out the hipstercircuits blog for good info on displays and capes.
Louis
I suppose BBW boots with the kernel 3.2 which does not have DTC support. Am I right?
If you are running the latest image, it is 3.8. That is what I am running on a couple of BBW.
Thank you Louis, I figured it out that I could start looking a some existing driver but then I found about the 3.8 kernel changes regarding the 3.2 kernel and got a little confuse.
I would like to learn more about Linux drivers for embedded devices, is there a good place to start looking at?
Xavier
