but because of a stupid error had to upgrade (wiped a partition on the SD card by mistake).
Anyway on the new install the HDMI was working correctly, showing text on startup. I then installed LXDE & no more HDMI. ‘Tux’ is shown in the top left hand corner for the initial couple of seconds but then the TV gives up & shows no signal. I’ve edited /boot/uEnv.txt to:
xrandr -display :0.0 -q
Screen 0: minimum 320 x 200, current 720 x 480, maximum 2048 x 2048
DVI-D-1 connected 720x480+0+0 160mm x 90mm
800x600 56.2
720x480 (0x43) 27.0MHz
h: width 720 start 736 end 798 total 858 skew 0 clock 31.5KHz
v: height 480 start 489 end 495 total 525 clock 60.0Hz
After connection to the TV:
ubuntu@arm:~$ xrandr -display :0.0 -q
1280x1024 60.0
720x576 50.0
720x480 60.0* 59.9
