hello
I installed ubuntu 12.04 in emmc memory. because I need sdio interface for another device.
But BBK cannot mount usb stick memory.
When i insert usb stick memory in BBK , logo is as below.
How can I mount usb stick memory beagle board.
May it need udisk2?
if needed udisk2 how and where can I get udisk2 in beagle bone ubuntu.
I am waiting for your reply.
thank u.
buntu@ubuntu-armhf:/media$ [ 213.188718] sd 2:0:0:0: [sda] No Caching mode page present
[ 213.194637] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 213.222809] sd 2:0:0:0: [sda] No Caching mode page present
[ 213.228759] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 213.288317] sd 2:0:0:0: [sda] No Caching mode page present
[ 213.294330] sd 2:0:0:0: [sda] Assuming drive cache: write through
ubuntu@ubuntu-armhf:/media$
ubuntu@ubuntu-armhf:/media$ dmesg | tail
[ 213.184549] sd 2:0:0:0: [sda] Write Protect is off
[ 213.184607] sd 2:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 213.273099] sda: sda1
[ 213.300852] sd 2:0:0:0: [sda] Attached SCSI removable disk
ubuntu@ubuntu-armhf:/media$ [ 726.051209] tilcdc 4830e000.fb: timeout waiting for framedon
ubuntu@ubuntu-armhf:/media$ ls -al
total 8
drwxr-xr-x 2 root root 4096 Apr 21 06:08 .
drwxr-xr-x 23 root root 4096 Apr 21 07:02 …
/etc/udev/automount script
Start at sdb to avoid system harddrive.
KERNEL!=“sd[a-z][0-9]”, GOTO=“media_by_label_auto_mount_end”
#Import FS infos
IMPORT{program}="/sbin/blkid -o udev -p %N"
Create a label
ENV{dir_name}==“usbhd-%k”
#Global mount options
ACTION==“add”, ENV{mount_option}=“defaults, relatime”
#Filesystem-specific mount options
ACTION==“add”, ENV{ID_FS_TYPE}==“vfat|ntfs”, ENV{mount_option}=="$env{mount_option},utf8,gid=100,umask=002"
#Mount the device
ACTION==“add”, RUN+="/bin/mkdir -p /media/%E{dir_name}", RUN+="/bin/mount -o $env{mount_options} /dev/%k /media/%E{dir_name}"
Clean up after removal
ACTION==“remove”, ENV{dir_name}!="", RUN+="/bin/umount -l /media/%E{dir_name}", RUN+="/bin/rmdir /media/%E{dir_name}"
Exit
LABEL=“media_by_label_auto_mount_end”
