Beagle actions for Rev C validation software image
Based on our meeting this morning, here are the actions I took down for finalizing our Rev C validation image this week. All validation code and processes will go on http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation.
Jason:
* Provide list of commits to pull for u-boot. (This will build the recovery u-boot that ignores the environment variables on the flash, not just the one that will go into the flash.)
* Clone Linux kernel w/ OE patches to gitorious in case beagleboard.org crashes.
* Provide new ramdisk image based on the Arago overlay of Angstrom that is smaller and will boot faster. (Steve will test.)
Khasim:
* Provide source links to svideo and evtest utilities on the wiki page. (Jason may try to incorporate into the ramdisk image script build so they aren't hacked-in.)
* Use another splash screen that works with Pico Projector. (Try the old one, but check with Koen why the Angstrom demo won't boot with it.)
* Provide patch for I2C bus switch fix patch. (Include Beagle mailing list)
* Work on reading the ADC for active power measurement.
Steve K.,
See below...
Google Code Archive - Long-term storage for Google Code Project Hosting..
Jason:
crashes.
Hopefully the mailing list won't find this "down-in-the-guts" work to
be too much noise. I'm hopeful that by being open for the Rev C
release we can generate better support collateral out of the
community.
I haven't had a chance to test this yet.
I've generated a new minimal file system build at:
http://www.beagleboard.org/~arago/arago-deploy/images/beagleboard/arago-base-image-beagleboard.ext2.gz
To build this, I used tag "validation-20090127":
http://www.beagleboard.org/gitweb/?p=arago.git
For mplayer and other utilities, look at:
http://www.beagleboard.org/~arago/arago-deploy/ipk/armv5te/
To build these, I used tag "validation-20090127":
http://www.beagleboard.org/gitweb/?p=arago-oe.git
Khasim,
See below...
Steve K.,
See below...
Jason:
I have applied my patches against the head of your tree on a branch
called 'for-khasim':
http://gitorious.org/projects/beagleboard-default-u-boot/repos/jason-clone/logs/for-khasim
This is built (and untested) at:
http://www.beagleboard.org/~arago/u-boot.bin
http://www.beagleboard.org/~arago/u-boot-f.bin
crashes.
It will go here when Gitorious I finish uploading it (will apply a
validation-20090127 tag):
http://gitorious.org/projects/beagleboard-diagnostic-kernel
Jason Kridner wrote:
Khasim,
See below...
Steve K.,
See below...
Jason:
Any plans to fix dss_init() in
http://gitorious.org/projects/beagleboard-default-u-boot/repos/jason-clone/blobs/for-khasim/board/omap3/beagle/beagle.c
Doing stuff like *((uint *) for register access could be broken? Using
potentially broken code for validation sounds strange.
Use readx/writex?
Fix hard coded 0x48310034 = 0xfefffedf; stuff?
Dirk
Khasim,
See below...
Steve K.,
See below...
Jason:
Use readx/writex?
Dirk,
Can you point to a link/example with the proper format? I assume this
is for the clock init accesses, correct?
Also, I'd really welcome a patch that works on HDTVs and the Pico
projector. The old splash screen worked with the Pico projector and
many HDTVs. The current dss_init() doesn't work with any display that
I have, but it must be working with some DVI-D monitors.
All of the DVI-D monitors and PICO that I have tried do not work as well.
Op 27 jan 2009 om 16:08 heeft Jason Kridner <jkridner@beagleboard.org>
het volgende geschreven:\
Steve K.,
See below...
for
code and
Jason:
recovery
just the one
beagleboard.org
crashes.
that is
community.
It's a bit sad that we're going to miss out on NEON and vo_omapfb by
going armv5te :frowning:
Koen
Koen,
See below...
Steve K.,
See below...
for
code and
Jason:
recovery
just the one
beagleboard.org
crashes.
that is
community.
Koen,
I am rebuilding 'mplayer' now with 'MACHINE=beagleboard bitbake
mplayer', so that concern should go away. It shouldn't matter much
about this mplayer, since it should only be used to test the hardware.
Can you consider inclusion of:
mplayer and FFmpeg dependency changes:
http://www.beagleboard.org/gitweb/?p=arago-oe.git;a=commitdiff_plain;h=0b53219005c8daa95bcff40742d7c807bda17eca
automatic execution /media/mmcblk0p1/boot.sh:
http://www.beagleboard.org/gitweb/?p=arago-oe.git;a=commitdiff_plain;h=064597b9db33efbef17ca9193a1ba222a07cc7fd;hp=51d7a5e16071023433078839e79a7e33daddd1e1
Jason
Koen,
I am rebuilding 'mplayer' now with 'MACHINE=beagleboard bitbake mplayer', so that concern should go away. It shouldn't matter much about this mplayer, since it should only be used to test the hardware.
Hmm, I like these curl-inspired *_FEATURES handlers. The only problem with those is they won't trigger automatic rebuild when the featureset in the variable changes - don't forget to run bitbake -c rebuild manually...
Adding oe-dev mailing list...
Koen,
Can I get a few comments on [1]? I found there is also a dependency
in libtheora on x11 that doesn't seem necessary. I find this very
useful to avoid making a new recipe. Anyone have ideas to address
Denys' concern about needing to issue 'bitbake -c rebuild'?
I'm against adding such 'USE flags' to OE, they basically make QA impossible. If people want a different mplayer, they are free to make an 'mplayer-nox' or 'mplayer-nosdl' recipe to fill their needs.
regards,
Koen
>> Koen,
[1] http://www.beagleboard.org/gitweb/?p=arago-oe.git;a=commitdiff_plain;h=0b53219005c8daa95bcff40742d7c807bda17eca
For some reason Koen's reply never made it to the oe-dev list... Sorry for
copying it here to continue the discussion.
But on the other hand it would make overlays, such as Arago, as well as OE
itself, much cleaner and reduce the recipe creep.
As of the rebuild issue when featureset in the variable changes, I was
thinking about storing a hash of variable's value, in addition to the
standard version and revision numbers, should trigger an automatic rebuild.
Similar to bumping up a PR, but without modifying the recipe. Any thoughts?
Is it possible in OE to generate an ipk file name that gives some
indication of the USE flags? Perhaps the right way to do this is with
a common .inc file to avoid maintenance issues.
If it magically mangles package names, what's so different from creating multiple recipes?
regards,
Koen
I think the differences are the names being sensible (based on having
multiple recipes and using a .inc file to avoid maintenance issues)
vs. maintaining fewer recipes. The USE flags also give greater
flexibility at the distribution level, but I've only seen a limited
number of cases for which this is currently required. As long as the
recipes give ?= assignments, "personal" distributions could still be
generated at the local.conf level. The idea to add a hash to trigger
an automatic rebuild if relevant USE flags change still seems quite
useful (and even putting the USE flags into the control file).
That still doesn't the really address QA flaws I pointed out, weakly assigned USE flags should *never* be in OE metadata. If you assing the nosdl flag in the mplayer-nosdl.bb, what's the use of weakly assigning it?
regards,
Koen
Khasim,
below...
With the validation kernel on the wiki, I find that 1280x720M-24@60
works well with my HDTV. The u-boot doesn't provide any splash screen
for me.
Also, note Dirk's comments below.
>> Khasim,
>> See below...
>>> Steve K.,
>>> See below...
>>>> for
>>>> and
>>>> Jason:
>>>> recovery
>>>> the one
> Use readx/writex?
Dirk,
>>>> beagleboard.org
>>>> crashes.
>>>> that is
>>> community.
This seems to have some problems with the inittab. The image on the
Rev C validation wiki page doesn't seem to be compressed, so that may
be some of Gerald's boot performance issues!
So far, my attempt to build for armv7a has failed. I'm redoing it
with X-nox.bb files.
Khasim,
below...
for me.
> Gerald
>> >> Khasim,
>> >> See below...
>> >>> Steve K.,
>> >>> See below...
>> >>>> for
>> >>>> and
I've placed several notes on this page regarding issues. Please
provide instructions on exactly what was added to the Arago image.
>> >>>> Jason:
>> >>>> recovery
>> >>>> the one
>> > Use readx/writex?
>> Dirk,
>> >>>> beagleboard.org
>> >>>> crashes.
>> >>>> that is
>> >>> community.
The inittab issue was actually due to a typo in my bootargs. I've
placed bootargs that work with my HDTV in the wiki comments.
