Beagle Android PMEM device
Hi ,
I am trying to create PMEM device in the kernel.
I added the device as follows
static struct android_pmem_platform_data android_pmem_hwc_pdata = {
	.name = "pmem_hwc",
	.start = PMEM_HWC_BASE,
	.size = _PMEM_HWC_SIZE,
	.no_allocator = 0,
	.cached = 0,
Is that this Base address and size of this memory region should have been reserved while booting the linux with mem = ( TOTALSIZE - x ) ? Inputs on this front will be highly helpful .
it seems good. but normall pmem is physical memory allocated, this has been done for msm.
we can compare and check it out.
Thanks. And , i was able to see base is taken as (0x10000000 + 64*SZ_1M) in MSM. So, this would have been reserved from Linux Memory,with boot param as mem = 80M , right ?
[ linux/arch/arm/mach-msm/board-trout.h]
#ifndef __ARCH_ARM_MACH_MSM_BOARD_HALIBUT_H
#define __ARCH_ARM_MACH_MSM_BOARD_HALIBUT_H
#define MSM_PMEM_GPU0_BASE      (0x10000000 + 64*SZ_1M)
#define MSM_PMEM_GPU0_SIZE      0x800000
#define MSM_PMEM_MDP_BASE       (MSM_PMEM_GPU0_BASE + MSM_PMEM_GPU0_SIZE)
#define MSM_PMEM_MDP_SIZE       0x800000
#define MSM_PMEM_ADSP_BASE      (MSM_PMEM_MDP_BASE + MSM_PMEM_MDP_SIZE)
#define MSM_PMEM_ADSP_SIZE      0x800000
right. we have to allocate physical memory which is not being used by any other device, mmap or iomap range and give bootargs considerably.
u able to get pmem working with android.
Thanks and Regards,
HarishKumar.V
Yet to complete …
Yet to complete ..
I have the following configuration for pmem device :
/* PMEM device */
static struct android_pmem_platform_data omap_pmem_data = {
         .name = "pmem",
         .start = (120 * SZ_1M),
         .size = (8 * SZ_1M),
         .no_allocator = 0,
         .cached = 0,
And while booting the android image, i gave bootargs as mem=120M [.i.e
Reserving last 8 MB and used as pmem device], but after booting,
i am continuously getting the following error :
Unhandled fault: external abort on non-linefetch (0x1818) at 0x44a67000
Any clues will be helpful .
Shankar
