But, I have a problem with the display.
Seems like the resolution is not good. I need 800x480 but I don't know
where I can change it.
Also, I am running Android and the picture is not stable like a bad
transmition.
I suggest you ask the person that sold it to you. I have never seen this product before. It shows it plugged into a BeagleBoard-xM and not a BeagleBoard C4. I can only assume that it either has never been tested on a rev C4 or it does not work. In theory it should work, but again you need to contact the person that sold it to you.
Hi, I added a line in drivers/video/modedb.c lije you said, but no
result.
I am stumped because, I use the exact same .config from a kernel
précompiled which works fine, with the good resolution. But with my
own kernel that I compiled myself, the resolution is not good.
Do you have any others ideas hopefully ?
thanks again
You must change display to dvi in bootscr, not lcd by default.
I think this screen get output from dvi.
Here's my boot configure:
setenv bootargs 'console=ttyS0,115200n8 androidboot.console=ttyS0
mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootdelay=1 init=/init
ip=off omap_vout.vid1_static_vrfb_alloc=y vram=8M omapfb.vram=0:8M
omapdss.def_disp=dvi omapfb.mode=dvi:800x480MR-16@60'
