Beagle Board external DC power question
In the latest system reference manual, the external DC power
requirement is described as:
"8.2.2 Wall Supply Source
A wall supply can be used to provide power to the board. A regulated
5V DC supply of at
least 500mA is required. It needs to have a 2.1mm plug with a center
hot configuration."
I would expect that to mean a center-positive power supply connector.
However, the power input section schematic shows the input jack wired
to feed +5V from the *sleeve*, not the center (tip) conductor, and the
tip grounded.
Does the board then require a 5V wall supply with *negative* center
pin?
By the way, is there an email address for board support from the
vendor?
Dave Bell
It is center positve and sleeve to ground.
All support is handled via this mailing list.
