Beagle Board Rev B6
I have Beagle Board B6,i got the sources from git repositoriesthen i
built the MLO,u-boot.bin,uImage images using codesourcery tool.
I also got the filesystem http://code.google.com/p/beagleboard/wiki/BeagleSourceCode.
X-loader,u-boot is working fine but when i start to boot the kernel it
just hang there.
40T
Texas Instruments X-Loader 1.4.2 (Aug 8 2008 - 16:59:05)
Reading boot sector
Booting from mmc
U-Boot 2009.06-rc2 (Jun 05 2009 - 10:19:13)
OMAP3530-GP ES2.1, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #7436000200000000040316e806017006
OMAP3 beagleboard.org # mmc init
mmc1 is available
OMAP3 beagleboard.org # fatload mmc 0 0x80300000 uImage
reading uImage
17467890 bytes
OMAP3 beagleboard.arg# setenv bootargs console=ttyS2,115200n8 noinitrd
root=/dev/mmcblk0p2 re rootfstype=ext2 rootdelay=1 nohz=off
OMAP3 beagleboard.org#bootm 0x80300000
starting kernel.......
it display about ikernel image..
then uncompressing kernel....................
................done.kernel boots.
just hang there
Could any one tell me what is the reason?
I think your "setenv bootargs" command may be wrong.
Here's the command from the "Beagle Board Beginners": wiki //
elinux.org/
BeagleBoardBeginners#Writing_the_.C3.85ngstr.C3.B6m_image_into_the_SDcard_and_finally_booting_GNU.
2FLinux
# setenv bootargs 'console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw
rootwait'
I think you want "rw" instead of "re", and you need a rootdelay longer
than 1. "rootwait" is preferred to "rootdelay=n" nowadays.
The first time you boot Ångström takes a long time (minutes) to
initialize itself. Later boots are fast.
Hope this helps,
John
