I’m running a kernel Angstrom on Beagle xM. I can’t work with the network.
I tried with Nautilus and the network worked fine but I need the kernel source to enable the spi and so I’m running Angstrom now.
I can set Ip, netmask, … on usb0 but I get always this error message:
#ifconfig usb0 up
[ 45.825958] ADDRCONF (NETDEV_UP): usb0: link is not ready
The leds of the nework interface are turned off. I can’t ping external hosts.
uname -a
Linux beagleboard 2.6.32 #15 PREEMPT Fri Apr 13 13:01:23 CEST 2012 armv7l GNU/Linux
Any help?
I forgot to tell you that I’m using an ethernet cable linked to “eth0” and not an usb cable.
le 13/04/2012 14:49, SimoneBO nous a dit:
I'm running a kernel Angstrom on Beagle xM. I can't work with the network.
I tried with Nautilus and the network worked fine but I need the kernel source to enable the spi and so I'm running Angstrom now.
I can set Ip, netmask, ... on usb0 but I get always this error message:
#ifconfig usb0 up
Have you modified the file /etc/network/interfaces
You should have
auto usb0
then the usual stuff to configure your interface
I tried with dhcp and static IP.
It works and I can set the IP to usb0. But the network is still dead.
Maybe I can solve my problem with the new kernel?! Do you know where I can found the angstrom kernel’s source for beagle board xm?
I try with an image of Ubuntu and the network works, but not the SPI
I’m getting crazy…
The eth adapter should work with any kernel…
You don’t need the source of a newer kernel.
Visit http://www.angstrom-distribution.org/demo/beagleboard/
Then, download uImage (this is a 3.0.17 kernel) and
copy this file in the /boot directory of your root partition
copy again the file in the boot partition of your mmc card
Then download modules.tgz and untar in the root parition
You will have a fully angstrom distro with 3.x kernel
I need the spi on this board. The only way I found is to patch the “board init file” board-omap3beagle.c.
Do you know other way to enable the spidev?
I don’t know spidev, but if you really need to build a kernel you have to use openembedded, then configure and build your custom kernel
http://www.angstrom-distribution.org/building-angstrom
before bitbake virtual/kernel
you could
I compiled the angstrom kernel using the follow istructions:
http://linuxdeveloper.blogspot.it/2011/10/enabling-spi-on-beagleboard-xm.html
The image run but I have the network problem…
Ok, I found the solution to all my problems here:
http://www.brianhensley.net/2012/02/spi-working-on-beagleboard-xm-rev-c.html
Thanks Chris for your patience
Bye
