I powered the BBB over the DGND - VDD_5V. But by accident I plugged it into PWR_BUT.
Now it only gives a short blink at the power LED when powered. I know this is a bad sign… But does anybody of you know if this does not mean the end of it and if it can be somehow reset?
Hi, my Beaglebone Black have the same behavior, gives a short blink at the power LED when powered.
But, I turned on via usb connector with power supply 5V@1A. What may have happened?
Sounds like an overvoltage condition on the 5V DC input may have damaged the DC input. Usually from a cheap 5V power supply. If the USB power works, then the rest of the board is OK.
If the BBB will run from USB power, then the BBB is probably OK.
Put an oscilloscope on the output of the power supply that is causing the problem, and watch what the voltage does when you turn things on.
I had a bench power supply (B&W 1550) that when set to 5 Volts, then the output turned on, would throw a transient up to 6 Volts then return to 5 Volts. (The bigger the capacitor across the load, the greater the transient.) This would trip the over-voltage detect in the BBB power supply, which would blink the power LED once, then off after that.
So, make sure the power supply is working properly. Some of the cheap power supplies out there will NOT run a BBB.
I do not think the problem is the power sypply. I was using the same power supply before the problem occurred, power supply is functioning normally, I use it to charge my cell phone!
In this video, https://youtu.be/qojeLqazkK8, I tested two power supplies. The same that I have used to power up through USB connector and a common DC power supply. Nothing else works
I was thinking about what you said trip the over-voltage detect, and looking at the schematic realized that there is no protection, i.e. ncp349.
So, a small voltage variation, such as 6V, in the USB connector can brick the board?
