Dear BeagleBone Team,
I am currently using the BeagleBone Black for a data logging application. At present, i need mounting cape that can be fixed onto the BeagleBone card and supports the following:
Three (3) DB-9 RS-485 communication ports
An integrated Real-Time Clock (RTC)
A wide input power supply range of 9 V to 30 V DC
I would appreciate it if you could advise whether you have a suitable solution available or recommend a compatible board / cape that meets these requirements.
Thank you for your support. I look forward to your response.
