I am planning to start a project based on a beagle bone. I want to ba able to connect a tft display by spi and a microcontroller (DAC) by I2C bus.
The tft display is http://www.adafruit.com/products/358.
I also need to :
plug a analog potentiometer
drive relays
So what should I need to plug everything ?
I have a level shifter to plug the beagle bone I2C (1.8V I think) on the 5V I2C bus of the dac (adum part).
I have also some opto coupler like TIL111.
Here are some news if it can help other people with the same needs.
My goal currently is to use the angstrom cloud9ide image if it is possible (I need to verify that following stuff is included).
For the tft display I bought the 1.8 tft display from adafruit based on the ST7735 controler.
Luckily Matt Porter developed an spi framebuffer driver for this controler.
The video is here but the sound is not complete : http://video.linux.com/videos/spi-framebuffer-driver
The ppt is here : http://elinux.org/images/1/19/Passing_Time_With_SPI_Framebuffer_Driver.pdf
As pointed in the ppt, the level shifter on the tft doesn’t allow to drive the lcd to 16Mhz but there is a hack : disable the cd4050 shifter.
So it should be easy to use this particular tft lcd. I don’t if the driver is in the image but the code is available on github.
Now for the analog potentiometer, it is a really basic use of the board, the caveat is to use 1.8v input voltage which is available from on of the port. It is said to be only a reference but it seems usable (I will use a 50k pot or more).
It seems I2C port is available without specific stuff.
I will try i2cdetect -l to see what is found.
So it looks promising, I should be able to avoid kernel compilation for basic testing, but for the complete configuration I will need to dive in (OE seems the way to go).
All in all, there is a lot of resources, but it needs some work !
