Hi guys!
Does any one know when Beagle WLAN adapter be available for
purchasing? I can see it at the Beagleboardtoys.com but the link is
not available.
Hi guys!
not available.
Right now we they are looking for SW support on it from TI. TI failed to provide support as promised. Until that happens, it will not be sold. Supposedly there is progress on that front, but nothing solid. It was sold for a shor time, but with no support, it was pulled.
Gerald,
does design represented on the picture at beagleboardtoys work or not?
Yes. It does work. But only on 3.0. At the time of the initial release 3.0 was not ready and there are no drivers for the earlier versions of the kernel.
Gerald, and what is wrong with 3.0 if it works? Why don't you release
the board with 3.0 and wifi will just work?
Does it have the WL1271 chip under the hood like the other wifi modules from LS Research?
They may do it. But there are other issues involved like being able to get the WIFI modules. You need them in order to be able to build the boards. I will check with them.
Yes. And, they do have about 10 boards and I convinced them to start selling them again.
Gerald,
unveil the secret: is WL1271 connected to BB as defined here?
http://processors.wiki.ti.com/index.php/OMAP35x_Wireless_Connectivity_Solution_Hardware#WLAN_Configuration
I don’t know. I was not involved in its creation.
Since I could not buy one of these boards, I wired up the same LSR module on a veroboard using the circuit used on the Beagle Wlan and the WL12xx driver in 3.04 worked fine.
John
Hello John!
Can you share a scheme how you connected LSR module to BB? I have a
vew LSR modules but don't know how to connect them to BB-xM.
HI,
Could you tell me what USB wifi dongle you are using on BeagleBoard-xM. Please tell me because i am going to buy it.
Regards
~Sumit Gemini
Does anybody know if it is necessary to provide 32kHz clock source to
Tiwi-R2 module? It is stated in the datasheet but I'm not sure that it
is a demand.
Thanks!
John, is the veroboard running Linux, or are you running C directly on
the processor with no OS?
I guess there is no open source driver available. So Linux is the only option
From: beagleboard@googlegroups.com [mailto:beagleboard@googlegroups.com]
On Behalf Of Maxim Podbereznyy
Sent: Wednesday, November 16, 2011 9:55 PM
To: beagleboard@googlegroups.com
Subject: Re: [beagleboard] Beagle Wlan adapterHello John!
I followed the BeagleBoard Wlan schematic. You need a 3.3V voltage regulator
and a 32.768KHz oscillator. The LSR module will not respond without the
32.768KHz oscillator. The veroboard is just a 1.25mm pitch prototype board
and I used 30 AWG wire to connect the LSR module to the board. I have about
5mm between the LSR module and the prototype board since the holes on the
board don't line up with the LSR module. I hope this helps.
John
module on
driver
> Regards,
> John
[mailto:beagleboard@googlegroups.com] On
> Behalf Of Gerald Coley
> Sent: Wednesday, November 16, 2011 9:10 AM
> I don't know. I was not involved in its creation.
> Gerald
> Gerald,
on
>> selling them again.
>> Gerald
modules
>>> from LS Research?
>>> You received this message because you are subscribed to the Google
Groups
>>> "Beagle Board" group.
>>> To view this discussion on the web visit
>>> https://groups.google.com/d/msg/beagleboard/-/WKS5LK8g7BwJ.
>>> To post to this group, send email to beagleboard@googlegroups.com.
>>> To unsubscribe from this group, send email to
>>> beagleboard+unsubscribe@googlegroups.com.
>>> For more options, visit this group at
>>> http://groups.google.com/group/beagleboard?hl=en.
Groups
Groups
Groups
Groups
Sent: Thursday, November 17, 2011 9:42 AM
Subject: Re: [beagleboard] Beagle Wlan adapterDoes anybody know if it is necessary to provide 32kHz clock source to
is a demand.
Yes, you will need this clock or else the LSR module will not respond.
Thanks!
> HI,
BeagleBoard-xM.
> Thanks
> Regards
> ~Sumit Gemini
>> Hello John!
>> > module on
>> > driver
>> > Regards,
>> > John
>> > On
>> > Gerald
>> > Gerald,
on
>> >> selling them again.
>> >> Gerald
>> >>> modules
>> >>> from LS Research?
>> >>> Groups
>> >> Groups
>> > Groups
>> > Groups
>> > Groups
Groups
Groups
On Behalf Of Nathan McCorkle
Sent: Thursday, November 17, 2011 11:18 AM
Subject: Re: [beagleboard] Beagle Wlan adapter> Since I could not buy one of these boards, I wired up the same LSR
module on
driver
The veroboard is a 1.25mm prototype board used to connect the LSR module to
the Beagle-xM expansion connector.
John
> Regards,
> John
> Gerald
> Gerald,
on
>> selling them again.
>> Gerald
modules
>>> from LS Research?
Groups
Groups
Groups
Groups
Groups
Hey John!
Thanks a lot for such great instructions!
