[beagleboard] 3.8.13-bone53 USB Question / Help / Ideas
Hi all,
My previous email was incorrect, the USB Host port on the BBB works fine with the USB ASIC AX88x72A based Ethernet Dongle. So back to scratching my head....
I have identified in the dmesg output a 4 line difference between our custom board and the BBB.
Our custom board:
[ 1.562682] usbcore: registered new interface driver usbhid
[ 1.568560] usbhid: USB HID core driver
[ 1.573609] ashmem: initialized
[ 1.577327] logger: created 256K log 'log_main'
[ 1.582363] logger: created 256K log 'log_events'
[ 1.587701] logger: created 256K log 'log_radio'
[ 1.592803] logger: created 256K log 'log_system'
missing output
[ 1.600106] TCP: cubic registered
[ 1.603776] NET: Registered protocol family 10
[ 1.609549] NET: Registered protocol family 17
BBB:
[ 1.963408] usbhid: USB HID core driver
[ 1.968565] ashmem: initialized
[ 1.972295] logger: created 256K log 'log_main'
[ 1.977338] logger: created 256K log 'log_events'
[ 1.982576] logger: created 256K log 'log_radio'
[ 1.987699] logger: created 256K log 'log_system'
[ 1.992702] usb usb1: usb wakeup-resume
[ 1.992745] usb usb1: usb auto-resume
[ 1.992768] hub 1-0:1.0: hub_resume
[ 1.992808] hub 1-0:1.0: port 1: status 0101 change 0001
[ 1.995817] TCP: cubic registered
[ 1.999469] NET: Registered protocol family 10
[ 2.005445] NET: Registered protocol family 17
So, my question is what would trigger the USB drivers to skip the steps that generate the 4 output messages above? Or, what source file would I look at to determine what conditions would prevent the drivers from proceeding and displaying the above messages?
Any suggestions would be greatly appreciated.
Once again, with 3.15 our hardware and USB works perfect.
Ross
Hi all,
my head....
Our custom board:
missing output
BBB:
In your kernel source folder, issue the following command:
git grep cubic
There are only a few references so it should be easy for you to determine
why this doesn¹t happen.
John
Hi all,
my head....
Our custom board:
missing output
BBB:
git grep cubic
The missing ouput is:
Not the:
Thanks for the idea though..
Ross
  There are only a few references so it should be easy for you to determine why this doesn¹t happen. Regards, John
Hi all,
fine
my head....
Our custom board:
missing output
BBB:
git grep cubic
Sorry about that. These messages aren't from the kernel. Probably from
some startup script. You may want to try a tool like ack-grep to find the
source of these messages.
John
