I’m still working on the getting lirc working with my beagleboard & Ubuntu.
when I’m trying to load the module, I get these messages out:
[ 12.394775] lirc_serial: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.396392] lirc_serial: IRQ 74 busy
The reason I’m trying to use IRQ 74, is also from dmesg:
[ 0.000000] Kernel command line: console=ttyO2,115200n8 console=tty0 root=/dev/mmcblk0p2 rootwait ro vram=12MB omapfb.mode=dvi:1280x720MR-16@60 fixrtc buddy=none mpurate=auto
[ 0.000000] console [tty0] enabled
[ 0.764312] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 0.764556] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 0.764770] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.580017] console [ttyO2] enabled
[ 1.583953] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
I assumed this is because the serial port is taken by the console, but strangely releasing the port is not working:
ubuntu@omap:/etc$ sudo setserial /dev/ttyO2 uart none
Cannot set serial info: Invalid argument
If I try without sudo, I get “Permission denied”
Also strangely, when I try to look at the port status:
ubuntu@omap:/etc$ sudo setserial -g /dev/ttyO[0-3]
/dev/ttyO0, UART: undefined, Port: 0x0000, IRQ: 72
/dev/ttyO1, UART: undefined, Port: 0x0000, IRQ: 73
/dev/ttyO2, UART: undefined, Port: 0x0000, IRQ: 74
/dev/ttyO3, UART: undefined, Port: 0x0000, IRQ: 80
Shouldn’t there be something in that port address ? How about the undefined part ?
My /etc/serial.conf:
And /etc/modprobe.d/lirc-serial.conf:
options lirc_serial irq=74 io=0x49020000 debug=1
Could someone help out how the serial port is configuration should be done properly ?
Thank you.
