beagleboard angstrom compile failed
hello:
I’m trying to compile Angstrom for beagleboard, and it failed with the following msg…any clues…
/home/user/beagleboard/setup-scripts/build/tmp-angstrom_2008_1/sysroots/i686-linux/usr/armv7a/arm-angstrom-linux-gnueabi/bin/as: unrecognized option ‘-Qy’
make[2]: *** [build/genmodes.o] Error 1
make[2]: Leaving directory /home/user/beagleboard/setup-scripts/build/tmp-angstrom_2008_1/work/armv7a-angstrom-linux-gnueabi/gcc-cross-initial-4.3.3-r24.2/gcc-4.3.3/build.i686-linux.arm-angstrom-linux-gnueabi/gcc' make[1]: *** [all-gcc] Error 2 make[1]: Leaving directory /home/user/beagleboard/setup-scripts/build/tmp-angstrom_2008_1/work/armv7a-angstrom-linux-gnueabi/gcc-cross-initial-4.3.3-r24.2/gcc-4.3.3/build.i686-linux.arm-angstrom-linux-gnueabi’
make: *** [all] Error 2
  • die ‘oe_runmake failed’
  • oefatal 'oe_ru
    NOTE: package gcc-cross-initial-4.3.3-r24.2: task do_compile: Failed
This is on ubuntu machine and I got similar error when I build on Fedora…
On fedora it failed with …
/usr/bin/ld: cannot find -lc
thanks,
