Typically the SD card is only for flashing and is not needed. Plugging it in cam cause the board to hang.
Are you using the SD card for booting or flashing?
http://circuitco.com/support/index.php?title=BeagleBoneBlack#Loading_Software
Then I suggest that you reflash. Sounds like it may have started the flash process again and it was interrupted.
