[beagleboard] Beagle board xm C1 damaged
Hi Gautham,
The board is powered by a 7.4 v battery through a LM338 variable regulator set to 5V.
The display is powered by a 14.8 v battery through 7812 regulator.(requires 12v)
Please somebody help me identify the problem, bcoz i dont want to order for an other board without identifying the problem.
Hm, just as a safety precaution, I usually only use a single currency source to divert both currencies from. BTW, did you wire up the ground levels of the two batteries?
Best,
Mark
