[beagleBoard] beagleBoard mmc recovery failed
The nand flash is ecc failed when powering on, so I have to
do a mmc recovery according to the steps in the link:
  http://elinux.org/BeagleBoardRecovery#MMC_recovery
But each time doing mmc recovery, my beagle board hangs after
printing the messages:
Texas Instruments X-Loader 1.41
Starting on with MMC
Reading boot sector
717372 Bytes Read from MMC
Starting OS Bootloader from MMC...
I do not know how to recovery my board further, who can
help me to fix it?
Thanks!
  BeagleBoardRecovery - eLinux.org
Reading boot sector
help me to fix it?
Seems like you have a problem with uboot on you MMC card - The board as such
is starting fine, since it writes "Starting OS Bootloader from MMC..."
Try to double check the content on you MMC card - Might be you removed it
from your PC before all data was written to it thereby causing a corrupt
uboot?
Best regards - Good luck
  Søren
No, I can confirm the u-boot.bin is correct, also I try another MMC card and
the result is same. I guess nand flash init code stops at some point
because of
the nand ecc failure. If booting from nand flash, the uart message is :
        ECC Failed, page 0x00080700
        30 0 9f e5 0 c0 89 e5 f6 2d 0 eb 8c d0 89 e2 30 80 bd e8 e8 d5
e9 80 cc df e9 80 14
        e0 e9 80 38
       ~~~~ now bb hang.
How can I fix it? Who have found the problem and fixed it?
Thanks!
upgrade MLO to 1.42
Where can I get MLO 1.42 ?
Thanks!
> Thanks!
Google Code Archive - Long-term storage for Google Code Project Hosting.
Which one is 1.42? v1, v2 or v3?
Thanks!
于 Sat, 18 Apr 2009 11:14:55 +0200
Koen Kooi <koen@beagleboard.org> 写道:
>>> Reading boot sector
>>> help me to fix it?
>> board as such
>> MMC..."
>> removed it
>> corrupt
>> uboot?
> MMC card and
> point because of
> message is :
> d5 e9 80 cc df e9 80 14
> e0 e9 80 38
> ~~~~ now bb hang.
> How can I fix it?
upgrade MLO to 1.42
After upgrading mlo to 1.42, my board still cat't boot sucessfully,
the uart messages is :
  Texas Instruments X-Loader 1.4.2 (Feb 3 2009 - 15:34:17)
  Reading boot sector
  Loading u-boot.bin from mmc
  =========now the board seems died.
I am going to be crazy for the problem. Who can help me?
Thanks.
Reading boot sector
help me to fix it?
uboot?
MMC card and
point because of
message is :
       e0 e9 80 38
      ~~~~ now bb hang.
How can I fix it?
upgrade MLO to 1.42
  Reading boot sector
Take an other MMC card or delete your existing one and (re-) format it *exactly* like the manuals tell and put the binaries on it in the correct order. Try until it works :wink:
See
http://elinux.org/BeagleBoardFAQ#SD_Card
too.
Dirk
leiming said the following on 04/17/2009 08:54 PM:
http://groups.google.com/group/beagleboard/browse_thread/thread/d97b2152fe7185dd#
you may want to give this a shot if mmc recovery is tough...
Nishanth Menon
Thanks for your reply.
I have tried the usb & uart recovery under the guide of the link above,
and still failed, so I guess hw of the board has been destructed.
I am still a bit surprised about this, after all x-loader can work
correctly, but u-boot have not been booted successfully and does not
print everything. Maybe I need to dig into u-boot source code to locate
what is wrong about the board.
This is the usb & uart recovery information.
[lm@linux-lm beagle_recover]$ sudo ./recover_beagle.sh /dev/ttyUSB0
[sudo] password for lm:
NOTE:
When you see the message "Waiting for USB device..", Connect USB Cable
to the board with the switch S1 pressed Keep S1 pressed for 1 second at
least after connecting usb cable. Waiting for USB device
vendorID=0x451and productID=0xD009: Dev #37: Texas Instruments -
OMAP3430
  - Serial Number: N/A
Downloading file: 100.000% completed(38960/38960 bytes)
./target_files/u-boot-v2.bin downloaded successfully to target
Output:
lx
^C
NOTE:
vendorID=0x451and productID=0xD009: Dev #39: Texas Instruments -
OMAP3430
Output:
loadb -f /dev/ram0
## Ready for binary (kermit) download to 0x00000000 offset on /dev/ram0
device at 115200 bps... Match Found. Operation completed!
Downloading file: 100.000% completed(174632/174632 bytes)
File Download completed
Output:
go 0x80000000
## Starting application at 0x80000000 ...
/* not anything printed any longer */
Ming Lei said the following on 04/18/2009 10:11 AM:
NOTE:
OMAP3430
Output:
lx
^C
No.. dont hit CTRL+C. wait for it to come back to $ prompt.. it takes a
few seconds to continue.. but have a little patience..
NOTE:
OMAP3430
Output:
loadb -f /dev/ram0
Output:
go 0x80000000
Now, this is weird.. yeah board specific debugging is required.. :frowning: I
have a rev C and a rev A board and it worked out of the box.. for both.
log as an example:
$ ./recover_beagle.sh /dev/ttyUSB0
NOTE:
Keep S1 pressed for 1 second at least after connecting usb cable.
Waiting for USB device vendorID=0x451and productID=0xD009:
Dev #8: Texas Instruments - OMAP3430
Output:
loadb -f /dev/ram0
Output:
go 0x80000000
U-Boot 2009.03-00325-gf75a729 (Apr 09 2009 - 13:36:05)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Output:
0
OMAP3 beagleboard.org #
Output:
nand erase
NAND erase: device 0 whole chip
Erasing at 0x0 -- 0% complete.
<snip>
Erasing at 0xfae0000 -- 98% complete.
Erasing at 0xfd60000 -- 99% complete.
Erasing at 0xffe0000 -- 100% complete.
OK
Output:
nand write.i 80000000 80000 80000
NAND write: device 0 offset 0x80000, size 0x80000
524288 bytes written: OK
Output:
loadb 80000000
## Ready for binary (kermit) download to 0x80000000 at 115200 bps...
Downloading file: 100.000% completed(20392/20392 bytes)
Output:
nandecc hw
HW ECC selected
Output:
nand write.i 80000000 0 80000
NAND write: device 0 offset 0x0, size 0x80000
Output:
setenv bootcmd;nandecc sw;saveenv
SW ECC selected
Saving Environment to NAND...
Erasing Nand...
Erasing at 0x260000 -- 100% complete.
Writing to Nand... done
Nishanth Menon
above,
locate
> NOTE:
Cable
at
> OMAP3430
> Output:
> lx
> ^C
> NOTE:
Cable
at
> OMAP3430
> Output:
> loadb -f /dev/ram0
/dev/ram0
> Output:
> go 0x80000000
log as an example:
NOTE:
Output:
loadb -f /dev/ram0
Output:
go 0x80000000
DRAM: 128 MB
NAND: 256 MiB
In: serial
Output:
0
Output:
nand erase
<snip>
OK
Output:
Output:
loadb 80000000
Output:
nandecc hw
HW ECC selected
Output:
Output:
SW ECC selected
Erasing Nand...
You might have a problem with your external memory (the POP NAND and DDR). I
this case the x-loader will work with no problems (since it's only using
internal memory), while U-boot will/might fail (since it's run from external
memory)...
Does anybody have a validation test for external memory capable of running
from internal memory only?
Best regards
  Søren
Op 18 apr 2009, om 20:10 heeft Søren Steen Christensen het volgende geschreven:
above,
locate
NOTE:
Cable
at
OMAP3430
Output:
lx
^C
NOTE:
Cable
at
OMAP3430
Output:
loadb -f /dev/ram0
/dev/ram0
Output:
go 0x80000000
log as an example:
NOTE:
Output:
loadb -f /dev/ram0
Output:
go 0x80000000
DRAM: 128 MB
NAND: 256 MiB
In: serial
Output:
0
Output:
nand erase
<snip>
OK
Output:
Output:
loadb 80000000
Output:
nandecc hw
HW ECC selected
Output:
Output:
SW ECC selected
Erasing Nand...
memory)...
'memtest' in uboot2?
regards,
Koen
Koen Kooi said the following on 04/18/2009 01:18 PM:
Should be easy to enable from menuconfig if there is one..
Nishanth Menon
Yes , there is memtest in uboot-v2. I try to config ,compile and
download uboot2, but
not succeed to run it: there is anything shown in console after
downloading uboot.bin to
beagle. I guess the config is not valid.
Who can post a good beagle board .config for uboot v2?
Thanks!
"make omap3530_beagle_per_uart_defconfig" does work.
memtest has not passed indeed, maybe I need to replace omap3
chip.
于 Sun, 19 Apr 2009 12:53:34 +0800
Ming Lei <tom.leiming@gmail.com> 写道:
chip.
It seems there is something wrong about sdram data line D18 or address
line A18. Is it possible to fix it by choosing other sdram
configuration in initlization code?
Thanks!
X-load Beagle>icache
icache is enabled
X-load Beagle>icache 0
icache is disabled
X-load Beagle>mtest 0x80001000 0x80001040
Testing 0x80001000 ... 0x80001040:
Pattern 0xFFFFF00F Writing... Reading...
X-load Beagle>mtest 0x80001000 0x80002000
Testing 0x80001000 ... 0x80002000:
Pattern 0xFFFFFFFF Writing... Reading...
Mem error @ 0x800010A0: found 0xFFFBFFD7, expected 0xFFFFFFD7
Mem error @ 0x80001110: found 0xFFFBFFBB, expected 0xFFFFFFBB
Mem error @ 0x80001174: found 0xFFFBFFA2, expected 0xFFFFFFA2
Mem error @ 0x800011D4: found 0xFFFBFF8A, expected 0xFFFFFF8A
Mem error @ 0x80001248: found 0xFFFBFF6D, expected 0xFFFFFF6D
Mem error @ 0x800012A8: found 0xFFFBFF55, expected 0xFFFFFF55
Mem error @ 0x800012FC: found 0xFFFBFF40, expected 0xFFFFFF40
Mem error @ 0x8000135C: found 0xFFFBFF28, expected 0xFFFFFF28
Mem error @ 0x800013B4: found 0xFFFBFF12, expected 0xFFFFFF12
Mem error @ 0x80001430: found 0xFFFBFEF3, expected 0xFFFFFEF3
Mem error @ 0x800014A8: found 0xFFFBFED5, expected 0xFFFFFED5
Mem error @ 0x80001514: found 0xFFFBFEBA, expected 0xFFFFFEBA
Mem error @ 0x80001578: found 0xFFFBFEA1, expected 0xFFFFFEA1
Mem error @ 0x800015E0: found 0xFFFBFE87, expected 0xFFFFFE87
Mem error @ 0x80001648: found 0xFFFBFE6D, expected 0xFFFFFE6D
Mem error @ 0x800016B0: found 0xFFFBFE53, expected 0xFFFFFE53
Mem error @ 0x80001718: found 0xFFFBFE39, expected 0xFFFFFE39
Mem error @ 0x80001770: found 0xFFFBFE23, expected 0xFFFFFE23
Mem error @ 0x800017D0: found 0xFFFBFE0B, expected 0xFFFFFE0B
Mem error @ 0x80001848: found 0xFFFBFDED, expected 0xFFFFFDED
Mem error @ 0x800018BC: found 0xFFFBFDD0, expected 0xFFFFFDD0
Mem error @ 0x80001930: found 0xFFFBFDB3, expected 0xFFFFFDB3
Mem error @ 0x80001998: found 0xFFFBFD99, expected 0xFFFFFD99
Mem error @ 0x800019FC: found 0xFFFBFD80, expected 0xFFFFFD80
Mem error @ 0x80001A68: found 0xFFFBFD65, expected 0xFFFFFD65
Mem error @ 0x80001AC8: found 0xFFFBFD4D, expected 0xFFFFFD4D
Mem error @ 0x80001B30: found 0xFFFBFD33, expected 0xFFFFFD33
Mem error @ 0x80001B90: found 0xFFFBFD1B, expected 0xFFFFFD1B
Mem error @ 0x80001BE8: found 0xFFFBFD05, expected 0xFFFFFD05
Mem error @ 0x80001C5C: found 0xFFFBFCE8, expected 0xFFFFFCE8
Mem error @ 0x80001CD0: found 0xFFFBFCCB, expected 0xFFFFFCCB
Mem error @ 0x80001D48: found 0xFFFBFCAD, expected 0xFFFFFCAD
Mem error @ 0x80001DAC: found 0xFFFBFC94, expected 0xFFFFFC94
Mem error @ 0x80001E18: found 0xFFFBFC79, expected 0xFFFFFC79
Mem error @ 0x80001E88: found 0xFFFBFC5D, expected 0xFFFFFC5D
Mem error @ 0x80001EE8: found 0xFFFBFC45, expected 0xFFFFFC45
Mem error @ 0x80001F50: found 0xFFFBFC2B, expected 0xFFFFFC2B
Mem error @ 0x80001FB0: found 0xFFFBFC13, expected 0xFFFFFC13
Pattern 0xFFFFFFFE Writing... Reading...
Mem error @ 0x80001098: found 0xFFFBFFD8, expected 0xFFFFFFD8
Mem error @ 0x8000110C: found 0xFFFBFFBB, expected 0xFFFFFFBB
Mem error @ 0x80001174: found 0xFFFBFFA1, expected 0xFFFFFFA1
Mem error @ 0x800011E0: found 0xFFFBFF86, expected 0xFFFFFF86
Mem error @ 0x8000124C: found 0xFFFBFF6B, expected 0xFFFFFF6B
Mem error @ 0x800012AC: found 0xFFFBFF53, expected 0xFFFFFF53
Mem error @ 0x8000130C: found 0xFFFBFF3B, expected 0xFFFFFF3B
Mem error @ 0x80001368: found 0xFFFBFF24, expected 0xFFFFFF24
Mem error @ 0x800013C4: found 0xFFFBFF0D, expected 0xFFFFFF0D
Mem error @ 0x8000143C: found 0xFFFBFEEF, expected 0xFFFFFEEF
Mem error @ 0x800014AC: found 0xFFFBFED3, expected 0xFFFFFED3
Mem error @ 0x80001520: found 0xFFFBFEB6, expected 0xFFFFFEB6
Mem error @ 0x8000158C: found 0xFFFBFE9B, expected 0xFFFFFE9B
Mem error @ 0x800015F0: found 0xFFFBFE82, expected 0xFFFFFE82
Mem error @ 0x80001660: found 0xFFFBFE66, expected 0xFFFFFE66
Mem error @ 0x800016C0: found 0xFFFBFE4E, expected 0xFFFFFE4E
Mem error @ 0x8000171C: found 0xFFFBFE37, expected 0xFFFFFE37
Mem error @ 0x80001774: found 0xFFFBFE21, expected 0xFFFFFE21
Mem error @ 0x800017D0: found 0xFFFBFE0A, expected 0xFFFFFE0A
Mem error @ 0x8000184C: found 0xFFFBFDEB, expected 0xFFFFFDEB
Mem error @ 0x800018C8: found 0xFFFBFDCC, expected 0xFFFFFDCC
Mem error @ 0x80001944: found 0xFFFBFDAD, expected 0xFFFFFDAD
Mem error @ 0x800019AC: found 0xFFFBFD93, expected 0xFFFFFD93
Mem error @ 0x80001A18: found 0xFFFBFD78, expected 0xFFFFFD78
Mem error @ 0x80001A80: found 0xFFFBFD5E, expected 0xFFFFFD5E
Mem error @ 0x80001AD8: found 0xFFFBFD48, expected 0xFFFFFD48
Mem error @ 0x80001B38: found 0xFFFBFD30, expected 0xFFFFFD30
Mem error @ 0x80001B94: found 0xFFFBFD19, expected 0xFFFFFD19
Mem error @ 0x80001BF0: found 0xFFFBFD02, expected 0xFFFFFD02
Mem error @ 0x80001C68: found 0xFFFBFCE4, expected 0xFFFFFCE4
Mem error @ 0x80001CCC: found 0xFFFBFCCB, expected 0xFFFFFCCB
Mem error @ 0x80001D44: found 0xFFFBFCAD, expected 0xFFFFFCAD
Mem error @ 0x80001DAC: found 0xFFFBFC93, expected 0xFFFFFC93
Mem error @ 0x80001E18: found 0xFFFBFC78, expected 0xFFFFFC78
Mem error @ 0x80001E88: found 0xFFFBFC5C, expected 0xFFFFFC5C
Mem error @ 0x80001EEC: found 0xFFFBFC43, expected 0xFFFFFC43
Mem error @ 0x80001F4C: found 0xFFFBFC2B, expected 0xFFFFFC2B
Mem error @ 0x80001FAC: found 0xFFFBFC13, expected 0xFFFFFC13
Ming Lei said the following on 04/19/2009 12:16 AM:
These are POP(Package On Package). you may need to check on RMA
procedure - the device probably wont work in other configurations
Nishanth Menon
What is RMA procedure? Would you give me a detailed introduction?
BTW: the board is B5 revision.
Thanks!
