I built my own kernel with the scripts of Robert C. Nelson. I used the 3.8
branch (https://github.com/RobertCNelson/linux-dev/tree/am33x-v3.8) and
executed the following scripts- build_kernel.sh
- then I patched manually the rt patch 3.8.13-rt10
Last time i checked, there was a merge conflict in the cpsw network
driver used on the beaglebone with the rt patchset... 'So' did you
just ignore that *.rej file?
- rebuild.sh
- in make_menuconfig I activated the Fully Preemption
- install_kernel.shThe kernel is booting but I am not able to get the network running. Do I
have to change something in the config to get the network running?
