I think the problem is that it is detecting the sd card. If I am not mistaken, if it detects an sd at boot it tries to boot from it. Try removing sd card and reboot and see what it does.
-Wil
-Wil
Read that wrong. For some reason I thought it said beaglebone black.
-Wil
You should simply be able to rewrite the uimage to the boot parition. Here though I am assuming you rolled your own copy, but if not it is very likely that you would be able to extract the image from the install media if you used someone elses build.
