There is no fuse to protect the board from applying 5V direct to the processor that can only handle 3.3V. Best bet would be to request and RMA.
http://beagleboard.org/support/rma
Thank you…
Simone
If you applied 5V to the pins on the expansion header, from an Arduino, then you will need to remove the processor and put a new one on. If you are unable to do this yourself, then you should request an RMA and get it fixed.
thanks alot. i was driving bldc motor using l6235. I made sure that feedback pulses do not exceed 3.3v by placing a zenor. After sometime my beaglebone just stopped responding i.e 1 led flashes and then stops.So do u think only solution will be to replace processor, no other shortway? also i m from Pakistan and got beaglebone through a dealer sometime back in November 2012, do u think my RMA will be valid?
I know your RMA will be valid. Can I assume that the dealer was not an authorized distributor?
yes they may not be authorized. I think they bought it from digikey in USA through local office and then go it shipped here. But not so sure
OK. Put the RMA request in and reference me.
i did put RMA almost an hour ago. But dont know how to refer it to you.
I am Gerald. Just say you talked to me!
Thanks. RMA approved, will get it shipped in few days. May i know what problem could have caused this failure?
I cannot say. We do not know what your failure is until we look at the board.
