I haven’t been following the postings to closely related to the BBG and have run into a small problem.
I’ve built a new 4.1 system using Robert C Nelson’s instructions from the eewiki.
Root file system:
wget -c https:``//rcn-ee.com/rootfs/eewiki/minfs/debian-8.2-minimal-armhf-2015-09-07.tar.xz
Current /boot/uEnv.txt contents:
uname_r=4.1.12-bone16
dtb=am335x-bonegreen.dtb
cape_enable=bone_capemgr.enable_partno=BB-UART2
uuid=d8dfc06b-1696-4918-9a58-9c781183bbea
I used the flasher script:
bbb-eMMC-flasher-eewiki-ext4.sh
To copy the working uSD card to the eMMC
I followed the capemgr instructions for v4.1.x+ on the BBG after booting, no problems encountered there.
All is working except I’m getting capemgr load failures.
Partial dmesg output:
[ 4.319441] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 4.325219] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.332151] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 4.339003] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.346257] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.353462] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.360633] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 4.367574] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 4.379591] bone_capemgr bone_capemgr: Baseboard: ‘A335BNLT,▒,BBG115092762’
[ 4.386620] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4
[ 4.452718] bone_capemgr bone_capemgr: slot #0: No cape found
[ 4.512714] bone_capemgr bone_capemgr: slot #1: No cape found
[ 4.572715] bone_capemgr bone_capemgr: slot #2: No cape found
[ 4.632713] bone_capemgr bone_capemgr: slot #3: No cape found
[ 4.638499] bone_capemgr bone_capemgr: enabled_partno PARTNO ‘BB-UART2’ VER ‘N/A’ PR ‘0’
[ 4.646637] bone_capemgr bone_capemgr: slot #4: override
[ 4.651974] bone_capemgr bone_capemgr: Using override eeprom data at slot 4
[ 4.658978] bone_capemgr bone_capemgr: slot #4: ‘Override Board Name,00A0,Override Manuf,BB-UART2’
[ 4.668226] bone_capemgr bone_capemgr: initialized OK.
[ 4.673926] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[950000<->1325000]:-22
[ 4.684119] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[950000<->1325000]:-22
[ 4.752743] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 4.758870] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 4.765364] davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 4.772022] davinci_mdio: dt: updated phy_id[1] from phy_mask[fffffffe]
[ 4.783500] libphy: 4a101000.mdio: probed
[ 4.787547] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 4.797495] cpsw 4a100000.ethernet: Detected MACID = 84:eb:18:e6:d6:32
[ 4.805386] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
[ 4.814089] of_cfs_init
[ 4.816617] of_cfs_init: OK
[ 4.822601] PM: Hibernation image not present or could not be loaded.
[ 4.823538] Freeing unused kernel memory: 448K (c098a000 - c09fa000)
[ 4.903712] systemd-udevd[86]: starting version 215
[ 4.910405] random: systemd-udevd urandom read with 10 bits of entropy available
[ 5.627393] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.682949] bone_capemgr bone_capemgr: loader: failed to load slot-4 BB-UART2:00A0 (prio 0)
[ 5.857575] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 5.871367] systemd[1]: Detected architecture ‘arm’.
[ 5.904036] systemd[1]: Set hostname to .
[ 6.170629] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 6.188167] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
root@bbb-green:/# cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
root@bbb-green:/#
What have I missed if possible to tell from this info.
Ross
