Seems there is an experimental kernel driver for this chip under misc
sensors in the kernel tree. might look there and use that.
Eric
Eric
I believe that 8574-specific driver is deprecated, and the gpio-based replacement is bit-level only. Anyway, it isn't necessary. You can use the basic i2c drivers. I use something like this to communicate with 8574 devices:
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/i2c.h>
#include <linux/i2c-dev.h>
#include <glib.h>
#define I2C_BUS "/dev/i2c-3"
gboolean write_error_flagged;
gboolean read_error_flagged;
void I2C_Write(gulong address, guchar value)
struct i2c_smbus_ioctl_data argswrite;
argswrite.read_write = I2C_SMBUS_WRITE;
argswrite.size = I2C_SMBUS_BYTE;
argswrite.data = NULL;
argswrite.command = value;
int device = open(I2C_BUS, O_RDWR);
if ((device == -1) && !write_error_flagged) {
write_error_flagged = TRUE;
g_print_debug("ERROR: could not open I2C bus %s for writing\n", I2C_BUS);
return;
ioctl(device, I2C_SLAVE, address);
ioctl(device, I2C_SMBUS, &argswrite);
close(device);
guchar I2C_Read(gulong address)
union i2c_smbus_data data;
struct i2c_smbus_ioctl_data argsread;
argsread.read_write = I2C_SMBUS_READ;
argsread.size = I2C_SMBUS_BYTE;
argsread.data = &data;
argsread.command = 0;
if ((device == -1) && !read_error_flagged) {
read_error_flagged = TRUE;
g_print_debug("ERROR: could not open I2C bus %s for reading\n", I2C_BUS);
return 0;
ioctl(device, I2C_SMBUS, &argsread);
close(device);
return data.byte;
