[beagleboard] Beaglebone START_HERE.sh not found
Did you try this link?
http://circuitco.com/support/index.php?title=BeagleBone#Image_Files
I bought a BeagleBone Development Board from TI eStare (Order Number is 258705) on 7/31/2013.
From Sitara Linux Software Developer’s Guide I found the following:
When Beaglebone boots, a START_HERE directory will display on your Linux host desktop.
To start your evalaution and development using the BeagleBone, Run the START_HERE.sh script.
I tried to follow the above instruction. The Host PC OS is Ubuntu 12.04.1 LTS.
I use the following command from a Ubuntu terminal to connect Beaglebone to the host:
sudo screen /dev/ttyUSB1 115200.
Then I can see the BeagleBone boots, then I can login to root.
At the same time I can see a BEAGLE_BONE directory display on Ubuntu desktop.
However, I can never see a START_HERE directory. Of course, there is no START_HERE.sh script either.
The board does not ship with the Sitara SDK. You would need to install that to use the instructions you are trying to use.
