Please retry with gtkterm..
Hi Robert,
thanks for your quick reply.
Here ist the output from gtkterm:
NAND: No NAND device found!!!
0 MiB
*** Warning - readenv() failed, using default en
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
musb-hdrc: ConfigTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
muscpsw, usb_ether
U-Boot# ��+GCAP Unknown command '�
�+GCAP’ - try ‘help’
U-Boot# AT+GCAP AT+GCAP
Unknown command ‘AT+GCAP’ - try ‘help’
~x�x�x�~~x��T+���
That’s all
Bastian
Where are these AT commands coming from?
Here is what you should be seeing:
http://pastebin.com/kkX1XNXL
Is it something to do with board not getting enough power to start
with, so in middle of boot it dies.
I would connect the board to external DC wall power supply, instead of just usb.
that did the trick…
I now first connected the bone to the power supply, than added the usb cable.
Now the setup is starting.
Thanks again for your help
