[beagleboard] Bulk Order
Distributors buy in bulk all the time. Why do you need to order a lot of boards?
Yes. You need to talk to me.
This project is entirely open. Everything is accessible for your use. All HW and SW. You can use it as you like.
If you are asking if you can compete with what we do, at beagleboard.org, please refer to my first line of this email.
seems there might be some confusion here about whitelabel boards vs what is sent to distributors generally - i.e. different silkscreen layer and support model. the 2 are intended for different targets. Sounds like this project may be another candidate for whitelabel.
Eric
White label boards have no Beagleboard Logos and are not covered by a BeagleBoard warranty.
White label boards are the sole responsibility of those using said boards as to whether or not they can fulfill the desired application of the user…
They use all the same components that are used on the respective BeagleBoard.
They are tested on the same testers.
They are manufactured by the same company.
Special Computing is offering “White-label” BeagleBone boards with no minimum quantity to help commercial projects get started:
https://specialcomp.com/beagleboard/bone.htm#42602
