I have issues trying to upgrade the Beagleboard C4 ubuntu.
I followed the guide on http://elinux.org/BeagleBoardUbuntu , but both Method 1 and Method failed.
It seems like it fails in uboot, just before the actual kernel start.
Here is a full pastebin: http://pastebin.com/T6nnx1QP
And a small end of log:
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.4.1-armv7-x5 …
5699696 bytes read in 452 ms (12 MiB/s)
loading /boot/dtbs/4.4.1-armv7-x5/omap3-beagle.dtb …
107105 bytes read in 153 ms (683.6 KiB/s)
loading /boot/initrd.img-4.4.1-armv7-x5 …
12722954 bytes read in 969 ms (12.5 MiB/s)
debug: [console=ttyO2,115200n8 root=UUID=4817de6d-b3bb-4fb5-8157-492d5eedb08a ro rootfstype=ext4 rootwait musb_hdrc.fifo_mode=5 coherent_pool=1M quiet] …
debug: [bootz 0x82000000 0x88080000:c2230a 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x56f870 ]
Loading Ramdisk to 8f3dd000, end 8ffff30a …
After the Ramdisk line - device halts.
Additional info:
- MMC had passed badblocks test - so it should be fine.
- I have two identical Beagleboards C4 - and both fail in the same way. So it should not be hardware issue.
- Beagleboards are able to run old Ubuntu 9.10 - so again it seem to prove they are fine.
- I have tried “nand erase 260000 20000”
Questions -
- Have anyone a a copy of ubuntu >14.04 that works with Beagleboards Ax/Bx/Cx/Dx? Can you please share?
- Had anyone same issue as above? Google seem to be silent.
- Any other idea how to proceed? Can old NAND version of uboot affect the MMC boot when MMC has a new version of u-boot?
Best regards,
Alexander
