[beagleboard] can't boot kernel with latest u-boot
u-boot is compiled from
  commit 3bc8556f9b24af60dba2b55a0a.
linux kernel is Linux-2.6.30-rc7-omap1, and this kernel can be
booted by U-Boot 1.3.3 (Jul 10 2008 - 16:30:47).
The messages printed by uart is
U-Boot 2009.06-rc2 ( 6栽� 07 2009 - 17:05:21)
OMAP3530-GP ES2.1, CPU-OPP2 L3-165MHz
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision Ax/Bx
Die ID #22a8000200000000040316e80802100b
OMAP3 beagleboard.org # printenv
bootargs=console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw rootdelay=5
dieid#=22a8000200000000040316e80802100b
mtdids=nand0=nand
filesize=0
bootcmd=mmc init;fatload mmc 0 0x80300000 uImage;bootm 0x80300000
stdin=serial
stdout=serial
stderr=serial
Environment size: 243/131068 bytes
OMAP3 beagleboard.org # mmc init
mmc1 is available
OMAP3 beagleboard.org # fatload mmc 0:1 0x80c00000 uImage
reading uImage
2093396 bytes read
OMAP3 beagleboard.org # bootm 0x80c00000
## Booting kernel from Legacy Image at 80c00000 ...
   Image Name: Linux-2.6.30-rc7-omap1-gkh-05716
   Data Size: 2093332 Bytes = 2 MB
   Load Address: 80008000
   Entry Point: 80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux............................................................................. ................................................................................................
..... done, booting the kernel.
Ming Lei wrote:
u-boot is compiled from commit 3bc8556f9b24af60dba2b55a0a.
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0 OMAP3 beagleboard.org # printenv
mtdids=nand0=nand
filesize=0
stdin=serial
stdout=serial
stderr=serial
mmc1 is available
reading uImage
2093396 bytes read
OK
Starting kernel ...
Uncompressing
Please try
http://tiexpressdsp.com/index.php?title=FAQ_for_DaVinci_Linux#No_kernel_output_after_U-Boot_load
Best regards
Dirk
于 Sun, 07 Jun 2009 16:31:52 +0200
Dirk Behme <dirk.behme@googlemail.com> 写道:
Ming Lei wrote:
> Hi,
> DRAM: 128 MB
> NAND: 256 MiB
> In: serial
> Out: serial
> Err: serial
> mtdids=nand0=nand
> filesize=0
> stdin=serial
> stdout=serial
> stderr=serial
> mmc1 is available
> reading uImage
> 2093396 bytes read
> OK
> Starting kernel ...
> Uncompressing
Please try
Thanks for your reply.
When I enable the low level debug functions, the messages is
Uncompressing
