I am trying to compile “openssh” package to the rootfs using OE for angstrom distro. But not successful so far.
This is what I have done:
- Add this line to /recipes/images/console-image :
ANGSTROM_EXTRA_INSTALL ?= “openssh”
- Then I run:
bitbake console-image.
The compilation was successful, but the openssl package is not compiled into the rootfs.
I think that was because the “dropbear” package will be compiled by default, and therefore openssh was rejectected.
Can anyone help how can I config the OE so that “dropbear” will not be compiled but compiled “openssh” instead ?
Replace ?= with = and try ‘openssh-sshd’ if you want to use the openssh sshd as server.
regards,
Koen
Thanks, but the system still using dropbear, instead of openssh-sshd.
These are what I had done:
ANGSTROM_EXTRA_INSTALL = “ppp netkit-ftp openssh-sshd”
$ bitbake console-image.
Do I miss anything ?
Hey, I'm trying to get the zd1211 wifi driver to work on beagle. It seems there are a lot of incompatibilities with newer kernels in general. Did someone get it to work? Are there patches around? Unfortunately I found nothing appropriate.
I'm using 2.6.29 with "angstrom-2008.1". "bitbake zd1211" results in errors and the log-file presents a lot of kernel incompatibilities such as:
<--- snip --->
zd1211-driver-r85/src/zd1205.c: In function 'zd_writel':
zd1211-driver-r85/src/zd1205.c:704: error: 'struct net_device' has no member named 'priv'
<--- snap --->
But it is quite a lot, since I thought someone might have a patch for it or at least knows where I could find one.
Best regards
Sascha
Did you ever get a resolution to this? I have the exact same problem
as seen in the log file - no member named priv.
rob tow <robtow@tauzero.com> [2010-01-27 18:29:46]:
It's because of the new kernel, in which there's not priv member in net_device
struct, but ml_priv. Maybe you can try with this patch[1], which is for 2.6.29
AFAIK.
1. SOURCES: zd1211-2.6.29.patch (NEW) - - changes for .29
-- ynezz
Isn't the zd1211 driver upstream into the kernel already?
Koen Kooi <koen@beagleboard.org> [2010-01-28 10:16:16]:
Indeed. I was just telling him, why it's problem to compile it.
-- ynezz
If there was a working zd1211 driver in the Angstrom "deo" image. I'd
be happy. Or if I could compile from OE / bitbake I'd be happy, either
one.
one.
Try disabling NetworkManager in your image (e.g rename
/etc/init.d/NetworkManager to /etc/init.d/NetworkManager-disabled)
Reboot and your zd1211 dongle should be handled properly by udev. I'm
not sure what the root of the issue is -- other chipsets don't seem to
suffer this problem).
Steve
