That monitor is most likely just going to upscale the s-video signal:
Which is going to be around:
http://en.wikipedia.org/wiki/List_of_common_resolutions#Television
When you pick up the HDMI to VGA adapter make sure it actually
supports converting the Digital ONLY signals coming from the xM to VGA
Analog signals required by your display.
HDMI at Beagle gives only digital signals, therefore you will have to buy the expensive version of the HDMI-to-vga converter with a DAC inside
