[beagleboard] Cross-compiling ARM dependency issue
Where's your arm-gcc looking for headers? Probably not where you
think or want.
You could pass a '-I/path/to/headers' to your gcc compile command to
see if that helps. Or, just compile native on your beagle and save
yourself the "fun and excitement" of cross compiling :slight_smile:
-Andrew
Good to hear you got it to work. For the future, see if your toolchain
provider also has a way to get the headers and libraries configured the
way you need them to be. Copying headers _shouldn't_ be a problem
across architectures, until it is.
Cross compiler library and header dependencies can be a pain. If you
can, I strongly recommend native compiling over cross compiling. It'll
simplify your life and you'll live longer :wink:
-Andrew
